Old December 26, 2007, 01:01 PM
3.0charlie's Avatar
Not much to be gained with tighter timings, especially with 3dmark06. I believe you have reached the max of all your settings... only thing left is the video card to OC! Download Rivatuner, and play with it! You may be able to change the Crysis settings to Med-High, once the card is oc'ed.
Hydro-Quebec is salivating...
Old December 26, 2007, 04:45 PM
Prof. Dr. Silver's Avatar
Originally Posted by bushwickbill View Post
To run at 3.2Ghz I had to put V.core to 1.425 in Bios, CPU-z showed 1.328 when Orthos was running(Massive V-Droop?). So Being As CPU-Z is reporting such a V-Droop, I am not really putting 1.425 Volts into it right?
NEVER, EVER (!) trust CPU-Z for voltage readings! CPU-Z is known to 'misread' the Vcore. Use Everest or something similar. Now this doesn't mean that 1.4250V is bad for you CPU.
As a matter of fact....these Conroes like a little more juice....as long as the cooling is appropriate!
As for your RAM...your timings are pretty tight already, however you could leave them at 4-4-4-10 and see if you can squeeze some more MHz out of them, to make it run a little faster!
Good Luck
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old December 26, 2007, 04:55 PM
Default Card is OC'd
Currently my Max OC is 648/1566/891 Rock Stable!!
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
Old December 26, 2007, 07:53 PM
sswilson's Avatar
Yeah, from here on in, the only way you're probably going to get any more juice out of the memory is to muck about with the secondary timings and that's a whole new ball of wax which takes quite some time and a lot of effort.
Best bet is to play with what you've got for a while to make sure it's absolutely stable and then think about spending a weekend somewhere down the line to play with the secondary timings.
Secondary timing tweaking can be mind numbing, but I've managed to eek out 3%+ gains to benchmarks like super-pi (I think it also has a fair amount of effect on other pure # crunching apps like folding).
It's not for the weak of heart though.... a "too tight" secondary timing will more often than not require a hard c-mos reset to get the board to boot again so it's quite time intensive.
G.skill F2-8500cl5d BALISTX RAM 13 April 10, 2008 05:41 PM
Gigabyte GA-P35-DS3L and G.Skill RAM Supertrash CPU's and Motherboards 3 February 21, 2008 02:40 PM
Mushkin vs. G.Skill Kandorf RAM 2 September 18, 2007 02:45 PM
