Old December 22, 2007, 10:29 AM
Il Duce's Avatar
Default Possible to make a fanless rig with heatpipes and hs?
Not ocing but I was wondering if this is possible.
Old December 22, 2007, 10:36 AM
"Quote This..."
I suppose. One of those giant thermalright cpu towers and the new fanless 8800 gt.
given that your ps has a fan and your hard drive makes noise I'd opt for some 120mm on low speed though.
Zalman makes a completely silent case, but it's expensive.
::: Zalman :::
Old December 22, 2007, 01:08 PM
Sure.
But if you want to run with a closed case, you'll want some fans to push a little air through.
There are lots of good fans out there that are all but completely silent, so fanless isn't really all that necessary these days for silence.
A good heatpiped tower CPU cooler + the same on the video card, & some quiet fans, & you're set.
Fans to look at:
92mm = Nexus Real Silent (they really are; can't hear them at all)
Nexus 92MM Real Silent Case Fan Black 1500RPM 19.2DBA 27CFM 3/4PIN - DirectCanada
120mm:
Yate Loon (nice n cheap n quiet, though would likely need some undervolting to be completely silent)
Yate Loon D12SL-12 120MM Quiet Cooling Fan 1350RPM 47CFM 28DB 3PIN & 4PIN Sleeve Bearing Oem - DirectCanada
Yate Loon D12BL-12 120MM Quiet Cooling Fan 1200RPM 45CFM 24DB 3PIN & 4PIN Ball Bearing Oem - DirectCanada
Nexus 120mm
Nexus 120MM Real Silent Case Fan Orange 1000RPM 22.8DBA 36.87CFM 3/4PIN - DirectCanada
Nexus 120MM Real Silent Case Fan BLACK/WHITE 1000RPM 22.8DBA 36.87CFM 3/4PIN - DirectCanada
Noctua 120mm (my personal recommendation due to the look + included low RPM adaptors for even quieter operation - will do 900 - 1100 - 1300 RPM)
Noctua NF-P12-1300 120MM Ultra Quiet Cooling Fan 1100-1300RPM 63-92M3/H 12.6-19.8DBA Molex - DirectCanada
Scythe S-Flex 1200RPM
Scythe S-FLEX SFF21E 120MM Cooling Fan 1200RPM 20.1DBA 49.0CFM FDB - DirectCanada
800 RPM
Scythe S-FLEX SFF21D 120MM Cooling Fan 800RPM 8.7DBA 33.5CFM FDB - DirectCanada
Old December 22, 2007, 02:53 PM
I am considering going 100% passive in the future and I plan on using thermalright all the way. However, do you guys think its possible to run a thermalright HR-03 fanless and still run? I expect to see higher temps than the stock cooler, but as long as it works, im good for it. (I plan on using a total of 5 noctua NF-P12 in a TJ10).
Daily // 2.4GHz Mac Mini ::4GB :: 320GB HDD :: Apple Wireless Keyboard :: G5v2
Rig // PC-A7010 :: 1050W :: Rampage :: Q6600 :: 8GB :: GTX 260
X25-V :: 4x 1TB RAID-5 :: 2x 1TB RAID-1 :: 4x 1.5TB :: 1x 2TB
G15v2 :: MX-518 :: Xonar DX :: 7 Pro x64
2408WFP :: DT770/80 :: Onkyo TX-SR605 :: Klipsch RB-61 :: SVS PB10-NSD
Old December 22, 2007, 03:34 PM
Absolutely.
You just have to be comfortable with the card running very hot.
Here's why: AnandTech: Sparkle 8800 GT Passive: The Fastest Silent GPU in the World
They tested that in an HTPC case w/ fans OFF & it hit 111C & was still perfectly stable.
Goes to show that temps aren't as big of a deal as people make them out to be.
Obviously, that's a bit warmer than i'd like to run my video card @ 24/7, but with a few case fans in the case you mentioned, it'll be much better than those temps.
And with the HR-03, it supports 92mm right?
The Nexus 92mm fans i mentioned won't make any noise & would likely keep temps down.
Old December 22, 2007, 03:48 PM
Yeah, a 92mm fan can be added on it, I have a thermaltake 92mm fan currently on my HR03 and its painfully loud. Besides I plan on using the HR-03 in an SLI situation, which might not really work well with a fan due to space issues.
low heat emission power supply (fanless?) elninio Power Supplies 17 March 6, 2008 08:26 AM
Trying to make a mobo choice... Rausch CPU's and Motherboards 10 February 6, 2008 06:05 PM
anyone mod a cpu cooler with exposed heatpipes? solaris10 Water Cooling 7 January 18, 2008 12:27 PM
Techgage reviews Zalman Reserator 2 fanless water cooling kit Supergrover Reviews & Articles from the Web 0 February 15, 2007 09:57 AM
