Old November 4, 2010, 07:12 PM
BrianHanna's Avatar
Default How do i know if voltage is too high or low?
I've been trying to overclock my 6850 past 905/1095 (already a nice overclock).
how do i know what voltage is too much or too high?
i'm trying to get past stock voltage, but having never done that, i don't know the best way to do it without damaging the cards.
how do i do it?
Do i set the voltage higher, then incrementally increase the clock speeds?
How can i tell what caused a crash? if it was voltage too high, or low?
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old November 4, 2010, 07:37 PM
BrianHanna's Avatar
how does this look
Old November 4, 2010, 08:03 PM
around 1.4 should be a cap. some have pushed it more i think but the resulting temps will be...baad
btw run benches or have something looping, if it starts throttling youll see fps decrease past the point of (no) return
exemple : ASUS Radeon HD 6850 Direct CU 1 GB Review - Page 31/32 | techPowerUp
for everyday use, maybe 1.3. 1.325 or so
ADATA Introduces XPG Gaming Series DDR3-1333G Low Voltage Memory FiXT Press Releases & Tech News 1 August 31, 2010 02:28 PM
Low Cost - High Performance? TokeR New Builds 18 February 8, 2010 06:22 AM
OCZ Announces Low-Voltage AMD Black Edition Memory FiXT Press Releases & Tech News 1 September 25, 2009 10:55 AM
OCZ Technology Announces New DDR3 Low-Voltage Dual Channel Kits FiXT Press Releases & Tech News 1 August 25, 2009 07:47 PM
Northbridge SPP voltage on 780i too high? RA3KW0N Overclocking, Tweaking and Benchmarking 0 November 13, 2008 10:26 AM
