Old December 21, 2007, 10:05 AM
Rapid-X's Avatar
Default AMD ??
Know of any good programs that can auto overclock my amd system??its the one lsited in my sig. gettin a new asus board soon i hope.
Old December 21, 2007, 02:21 PM
chibi_man's Avatar
Auto Over Clocking is NOT recommended. My opinion, read and ask lots of questions so you can do it yourself. Auto Overclocking software can lead to hardware failure and other such fun events that can cost money to fix and replace.
_____________________________________
If you can't beat it...
Old December 21, 2007, 03:57 PM
werty316's Avatar
Ditto on that, BIOS overclocking is the only way to go.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old December 22, 2007, 02:56 AM
llama_egg's Avatar
Well, though OC should be done in the BIOS, Asus mobo's should go with a auto overclocking software for the CPU. Sure, it will OC it for you, but don't expect nearly as good OC's as doing it yourself
