Old October 28, 2010, 08:23 PM
Fudd Rucker's Avatar
Default i7 920 overclocking
I currently have my i7 920 @ 4.2ghz (200 x 21).
Id like to get a 233 bclk , but I cant get my QPI down due to lack of multiplyer options.
Ive got a slow mode option, how big of a hit would that be for performance as Ive come to see that the QPI is everything with these chips. I tried to
Any clue on how to achieve a 233blck or am I just wishing?
I couldnt think of something snarky or interesting to put here this time around.
Old October 28, 2010, 08:40 PM
whats your vcore? I know qpi is important but on my 930 I hit a bit of a wall at 4.2ghz would need a lot of volts on the vcore or qpi to go any farther for me at least.
Old October 28, 2010, 08:47 PM
1.36v on vcore, 1.355 qpi.
Old October 28, 2010, 11:05 PM
Okay that is basically what I have and I needed a ton of voltage to get it to boot let alone run some prime95 or intel burn test at 4.4ghz the temps got to hot with my wc but, I think you just need more voltage.
Old October 29, 2010, 06:00 AM
I was shooting for 233bclk because then I have the right number to run my ram full tilt. 186 and 233 are the numbers I need to get 1866 out of my ram.
Old October 29, 2010, 03:19 PM
what ram you got
its not easy to get 333 blk lol
myself i finally got 230blkx21 with e760
get the most out of your cpu
and lower timings are better than high clocks on x58;)
on p55 you need high clocks and the right strap for performance
on my secondary rig i have timings of 6-6-6-20 @ 1670mhz its just as fast as 2k cas8
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 30, 2010, 06:27 PM
What zsamz said.
I say just run your ram at 1600 with tight timings and max your CPU OC, I doubt you'll notice any real-world difference as opposed to running it at 1866. Unless you're a benchmark junkie
Old October 30, 2010, 06:59 PM
JD JD is offline
I think most X58 boards start to crap out past 200 BCLK but I could be mistaken. 233 BCLK is probably asking a bit too much.
Old November 2, 2010, 08:06 AM
To run over 220 bclk you'll need to turn up your PCIe frequency. You're looking in the range of 110-115 on the PCIe. That's the range that SATA drives start crapping out. So unless you're on an PATA, I'd say you're out of luck.
If this is a daily rig, I would definitely advise against this approach. Tighten up your timings and be done with it.
Obsessed with Benching...
Old November 5, 2010, 04:41 PM
ive given up on achieving a higher than 210bclk for now. Ive got my whole loop up and going, but my i7 is requiring crazy volts to stay stable and running. I can get it run 4.0ghz stable, but with an insane voltage and temps are pretty high considering. And idea of what could be the problem? I was thinking my ram, but its supposed to be a low voltage 1.5v 1866mhz kit and ive got it running 1600mhz stock volts. Recently upped the memory voltage and it seems to help.
Heres my following volts -
vCore - 1.39
vtt - 1.375
memory - 1.58
Temps are in the high 70s @ 4ghz for the cpu, amazingly enough my gtx 480 @ 800mhz is 43 under load and hasnt gone a mhz over during folding.
Id like to get these temps down and get a higher clock if possible for folding.
920 D0 stepping overclocking Wi-Fuzzy CPU's and Motherboards 10 May 1, 2010 02:17 PM
Overclocking i7 920 D0 voltages G777 Overclocking, Tweaking and Benchmarking 13 April 14, 2010 09:35 PM
overclocking 920 on rampage 2 gene = fail for me kyle_L Overclocking, Tweaking and Benchmarking 7 January 12, 2010 05:37 PM
New Proper Overclocking Results on i7 920 Rocco_360 Overclocking, Tweaking and Benchmarking 7 July 2, 2009 09:31 PM
Overclocking the 920 on the P6T Langiroth Overclocking, Tweaking and Benchmarking 18 June 6, 2009 01:51 PM
