Old November 8, 2010, 12:08 PM
wow thats alot of heat for just 4.0
thats way too much vtt for that setting
too much vtt can be a problem
thats one bad cpu to need so much juic for 4.0
is that the kingston lv you got ?
put 1.6v in it
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old November 8, 2010, 12:55 PM
LionRed's Avatar
Depending on what version Gigabyte X58A-UD5 you have. You might have to do a hard mod to achieve a higher overclock.
Choo Choo bitches, progress coming through.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy
Old November 8, 2010, 01:31 PM
idk but i wouldn't expect to reach 4900mhz or air or water anytime soon on a 920, unless it's only for a cpu-z shot
Old November 8, 2010, 10:40 PM
Fudd Rucker's Avatar
Got it sitting at 4.2 with better temps and volts. Seems my theory is working, I downclocked my ram to a super tight 1200mhz and dropped the voltage on that to 1.35v and that seemed to relieve a lot of stress on the chip in terms of volts and temps. Also hasnt fudged up yet after a few hours of folding on the chip.
I couldnt think of something snarky or interesting to put here this time around.
Old November 8, 2010, 11:27 PM
dont be too sure about that i'm verry close to acheiving 4.9 on water
and i'm not talkin about sc or suicideshot;)
my psu crapped out in leaktest i had to reseat block + shave standoffs cause pwm +nb temps went over 65c n i was about to run linx @ 231x21 1.52v
will get back to her as soon as i get my antec 1200 back from rma
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old November 9, 2010, 12:32 AM
Also got the temps problem under control. Flipped my fans around to pull heat from it rather than push the air out - dropped about 15 degrees just from that. Thinking maybe another set of fans for a push pull config to get optimal results.
edit - screw it, i ordered a pair of 38mm ultra kazes, those should solve all my problems now.
edit again : how well would it work to have the kazes push while the sflex's pull?
And if that doesnt do the trick, ill throw a single 120mm radiator in the mix and have that push pull with teh 2x sflex later on.
Old December 7, 2010, 08:40 AM
you have to be pretty lucky to get pass 220 bck... I haven't had such CPU yet :)
Old February 13, 2011, 11:09 PM
i got lucky
cpu got alot more in her
dont mind the voltage lol
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
920 D0 stepping overclocking Wi-Fuzzy CPU's and Motherboards 10 May 1, 2010 02:17 PM
Overclocking i7 920 D0 voltages G777 Overclocking, Tweaking and Benchmarking 13 April 14, 2010 09:35 PM
overclocking 920 on rampage 2 gene = fail for me kyle_L Overclocking, Tweaking and Benchmarking 7 January 12, 2010 04:37 PM
New Proper Overclocking Results on i7 920 Rocco_360 Overclocking, Tweaking and Benchmarking 7 July 2, 2009 09:31 PM
Overclocking the 920 on the P6T Langiroth Overclocking, Tweaking and Benchmarking 18 June 6, 2009 01:51 PM
