Old October 25, 2010, 06:24 PM
ZZLEE's Avatar
Default i7 920 C0/C1 Over 3 Ghz and seem stablel :):)
19 Multi 183 QPI
Highest CPU clock I have ever had seem stable so fare
wher do I go from here or just be happy
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old October 25, 2010, 06:27 PM
bojangles's Avatar
What your CPU cooler? You could probably push 1.35 V on that thing and adjust some other voltages a little to help.
Old October 25, 2010, 06:37 PM
ZZLEE's Avatar
Right now on intel stock cooler
Need the curage and no one in the house to install a Titan Fenrir
just saw in Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Overclock.net - Overclocking.net
He says as fare as I should go on stock air
Edit: the pic
had abetter score but didnt get a pic :(
Old October 25, 2010, 08:48 PM
rjbarker's Avatar
I was able to "stabilize" my 920 "CO" Chip at a nice 3.83 Ghz
QPI 201 Mhz x 19 (Turbo disabled)
RAM 2:8 (1608 Mhz)
Uncore x17
vTT +125mv
vCore 1.31875v
vDimm 1.66v
On a TRUE (Push / Pull) Max Temps under load around 72c.......
4 Ghz required a huge jump in Voltage / Heat.....wasn't worth it.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old October 25, 2010, 10:39 PM
ZZLEE's Avatar
thanks got to install cooler to play anymore bt thanks
Tags
fft-z , happy , overclock
Yeh 3.1 ghz ZZLEE Overclocking, Tweaking and Benchmarking 6 May 15, 2010 12:38 PM
4 Ghz stable(?) bkh2 Overclocking, Tweaking and Benchmarking 20 August 24, 2009 05:20 AM
I7 Stable @ 3.81 Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 March 10, 2009 11:37 PM
2.84 GHZ on Q9450 CTA Overclocking, Tweaking and Benchmarking 42 October 25, 2008 11:11 AM
I need help getting my e8400 to 4.0 Ghz dopedave Overclocking, Tweaking and Benchmarking 11 July 8, 2008 09:38 PM
