Old October 25, 2010, 07:39 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Go into the DRAM configuration menu and set Trfc to 110 across all four channels. It should give you a lot more bus speed & northbridge overclocking headroom.
Old October 25, 2010, 11:45 AM
Ah thx Mac!
Ya I'm not to experience with RAM settings, I basically just have it so I can clock higher stabily now, but I'm sure it could be tweaked for better performance. So my big issue now is my CPU cooling, lol, I have kind of a low speed fan on my Thermalright Ultra 120, and my PSU set up isnt helping, need to mount it on the bottom. Tempted to toss my watercooling loop onto it But i like the lesser maintenace aspect of aircooling. Might just throw a leafblower onto the cooler
Old October 25, 2010, 12:02 PM
MAC's Avatar
MAC MAC is offline
Download the AMD OverDrive (AOD) Utility, it will give you the most 'accurate' CPU temps. If you can keep AOD load temps under 55C, you're 100% fine.
Your Ultra-120 should have no problems keeping a Phenom II X6 under control, even while overclocked, especially since you really aren't using much voltage.
Old October 26, 2010, 11:44 AM
Hey guys, I want to say thanks, so far I've been testing 13 hours straight Prime 95 blend with no errors at 4Ghz with 1.47Vcore (update, 18.5 hours, Prime95 blend no errors :-)
Over the next week I'll post some more pictures showing my settings, and temps, and my final results
At the moment going to play around with some of the settings, see if I can get my RAM set a little more efficient. And Play with the NB frequency a bit,
Thanks for the input so far, extremely helpful
When I originally posted, I was running F2 BIOS, as I thought I was having issues with both F4 and F5, however after learning a little more of focusing more closerly on my RAM timings and speed. I updated to F5 and have no issue running the running the BUS at 286Mhz, and looks like I can go higher easily.
Old November 9, 2011, 04:31 PM
Your_friendly_gamer's Avatar
Hey Terrence,
This is exactly what I got now and I have never oc'd amd before, can you post what you had for different things for this combo? I would like to also hit 4.0
2000MHz Ram On AMD Phenom II X6 1090T & 890FXA-UD5 Slappa Overclocking, Tweaking and Benchmarking 0 October 15, 2010 07:13 AM
890fxa-ud5 cpu coolers bigshooter1974 New Builds 4 August 20, 2010 09:52 AM
GA-890FXA-UD5 Questions? Charmster CPU's and Motherboards 6 June 30, 2010 11:16 PM
GA-890FXA-UD5 - Help! Bios Updating Charmster CPU's and Motherboards 5 June 27, 2010 10:33 AM
Gigabyte GA-890FXA-UD5 Revealed Soultribunal Press Releases & Tech News 8 March 9, 2010 04:29 PM
