Old October 24, 2010, 10:15 AM
bvsbutthd101's Avatar
Default Having trouble getting my i7 930 stable @ 4 ghz
Here's my settings so far,
my system specs are in the system spec tab
Old October 24, 2010, 11:31 AM
rjbarker's Avatar
Their is no such as thing as an "easy" 4 Ghz STABLE OC.....seems many seem to think all chips will do this very simply.
I noticed (in your specs) the high OC of your 480....is this 24/7 or only for a single Vantage run? In other words reduce your GPU OC to a more reasonable level whle your trying to get your CPU stable.
Don't use Uncore "Auto"...try it at 2x RAM ...as in 3200Mhz
Try MCH Strap @ 1600 Mhz
Lower your QPI to around 195 - 198 Mhz.......why 201Mhz....?...try to keep your RAM at or slightly below spec until you find the sweet spot for your CPU (stable)
Try disabling VDroop....VDroop and vDrop have to be considered for adjusting voltages....once you find the stable voltage, you maybe able to apply VDroop / VDrop to the equation and re-enanble VDroop Control...personally most folks disable it when looking for higher OC's....much easier.
Your vCore looks extremely low for "enabled VDroop" considering your looking for 4 Ghz.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old October 24, 2010, 12:07 PM
it's all good now, 100 percent stable :) ran LinX with everything on max, 20 passes with no errors
for my 480, I didn't just do one vantage run, I used MSI kombustor multiple times to stress test and ran vantage several times. I know that's stable.
Old October 24, 2010, 07:40 PM
rjbarker's Avatar
Uh yeah......if your relying on LinX only for "solid stable" minimum 300 minutes (not passes) and Max Memory "All" enabled
Sorry, but 20 passes of LinX aint solid stable in my books ( a good quick indicator that you're on the right track is all that will show).......let it run P95 Small FFT and Blend each for minimum of 8 hrs, if you get through that your golden ;) (or Fold)
I wasn't wondering if your GPU OC was stable at all (could care less), but a highly OC'd GPU will generally effect the ability to "stabilize" an OC'd CPU......generally requires tweaking IOH vCore etc.....
Also.....why you running such a high OC with your 480 on a 19" Viewsonic monitor...pointless really....Stock speeds vs your OC speeds won't produce any better results gaming...only more heat
Just trying to help you out Bud
MARK 11: 32.530
Old October 24, 2010, 07:55 PM
I mostly play on my 46 in" tv at 1920 by 1080, plus the overclock doesn't create that much more heat, only a couple degrees. Max temps are between 75 c and 80 c with MSI Kombustor. So heat on the GPU isn't a huge issue for me.
Old October 24, 2010, 07:59 PM
chrisk's Avatar
Folding Captain
You are not kidding.
Over the course of the last week, I got my Asus P6T i7 920 combo (main rig) to 4.0GHZ first try (24 hours prime, 5 days folding)...my other P6T i7 920 folding rig (exact same config), I cannot get to 4.0 with my ram over 1140MHZ (I had a thread for that rig last December, and tried again this week with no luck).
Pretty sure the IMC/Uncore is picky on that folding chip, while the other rig has a chip that will take whatever I throw at it.
Fold for team #54196
Old October 24, 2010, 08:17 PM
Arinoth's Avatar
Agree with you there as well Chris. My 940 will do 4.0GHz, passes on practically all tests but still the odd time will fail it making me pull back to 3.8. I cant throw anything at it at 3.8, but 4.0 its 'picky'. I would recommend OP increase their vCore a bit more perhaps.
Here I am: here I remain
Old October 24, 2010, 08:45 PM
rjbarker's Avatar
Chris / Arinoth
What I have found with both my old 920 and now my new 980X is it seems to come down to the IMC of the Chip......I spent a good 3.5 weeks playing around with OC settings...tweaking...testing my 980X and can not get it stable at 4 - 4.1 Ghz without relatively high vCore (compared to many others).......anything less than about 1.375v forget it (thats with VDroop Disabled)...so its hitting 1.395v under full load.....still less than Intel recommended highest Voltage (1.4v..barely), but fortunately these Hexa Cores run quite cool with high voltages (32nm)..highest I saw under load was 75c...I think the main reason many were claiming such high OC's with low voltages was thier Stability Testing methods....LinX Max Memory doesn't prove squat with these Chips Hexa (we need a new LinX version for these Chips)...load temps are no where near what P95 Small FFT / Blend produces and 30 - 50 x passes of LinX resulted in very quick BSOD's when running P95...
I never get the golden chip......although at this point in time Im tempted to try a new Board...
Its not always easy hitting 4 Ghz......my older 920 C1 forget it without high Voltage and Temps....
MARK 11: 32.530
Old October 25, 2010, 06:25 AM
Chris / Arinoth
I was origanly using P95, and someone told me to use LinX because it stresses the cpu more, I just use both though.
Old October 25, 2010, 09:01 AM
chrisk's Avatar
Folding Captain
I like this thread:
Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Overclock.net - Overclocking.net
I think you have the basics already, but in that guide they include what BSODs and freezes, etc mean when running prime95...can help pin down what part of teh chip/setup is holding you back.
I7 930 OC 4.4 Now Stable Chromey Overclocking, Tweaking and Benchmarking 29 July 27, 2010 11:33 AM
Stable OC no longer stable? Arinoth Overclocking, Tweaking and Benchmarking 17 December 1, 2009 09:00 PM
4 Ghz stable(?) bkh2 Overclocking, Tweaking and Benchmarking 20 August 24, 2009 05:20 AM
I7 Stable @ 3.81 Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 March 10, 2009 11:37 PM
2.84 GHZ on Q9450 CTA Overclocking, Tweaking and Benchmarking 42 October 25, 2008 11:11 AM
