Originally Posted by MAC You probably dont need to disable LLC, but you can always try lowering the vCore a bit. VTT can have an impact on temps. |
I forgot to mention I tried lowering vcore but 1.275 was the lowest I could go without running into LinX errors/crashes. I just remember reading an article or something about having LLC enabled leads to higher load temps.
Also VTT = QPI on Asus boards right? I think I've got mine at 1.225 right now, I'll see if I can lower it any further, thanks.
