Old October 12, 2010, 02:59 PM
homer98's Avatar
Default Success ! 4Ghz
Hey all, just got my i7 930 to 4Ghz. Going to do some long term testing tonight. and then see if I can bring down the voltages a bit. any recommendations on how to make sure clocks are stable and minimal voltage required? Thanks
Old October 12, 2010, 03:04 PM
CTA's Avatar
CTA CTA is offline
congs... you should tell us about your computer rig... (not all computer rig is same)...
Old October 12, 2010, 03:12 PM
looking good. i sugest leaving folding@home run on it for a few months, just to be sure :)
hows temps?
Old October 12, 2010, 03:17 PM
homer98's Avatar
I will try and get some pics and tell you guys about the comp. After some quick tests ive got max temps of 69C 65C 64C 63C across the cores. Going to run linx tonight for a while. current voltage is at 1.288v.
Old October 12, 2010, 03:56 PM
thats good. you still have room for more juice.
Old October 13, 2010, 01:54 PM
homer98's Avatar
I might try to get some more out of if, but first im going to tweak the voltage as much as I can to get the best efficency. I'm very happy I got the Hyper 212, wasnt sure how it would handle 4Ghz but i am very satisfied of what it can do :P
Who knows, maybe I will get some folding going on this cpu in the near future heh.
Old October 13, 2010, 03:43 PM
much appreciated and good luck with future clocking :)
Why doesn't my AM2+/AM3 motherboard support this cpu?Success,it does! fourthman CPU's and Motherboards 8 September 25, 2010 01:30 PM
i7 4ghz :D vagnaar Overclocking, Tweaking and Benchmarking 18 January 16, 2010 01:41 PM
e5200 OC SUCCESS!! Bucklaz Overclocking, Tweaking and Benchmarking 29 February 16, 2009 10:57 AM
NewEgg.ca success story... Jake_HT Off Topic 8 January 22, 2009 11:55 AM
success story rma Off Topic 6 May 2, 2008 07:54 AM
