Old December 15, 2007, 08:23 AM
Hillsdale's Avatar
Default My 8800 Ultra/ E6600 Clocks
So ever since ive gotten my 8800 Ultra ive been scared to Overclock my 8800 Ultra. Well i thought what the h*ll and im now overclocking it. Im using ATI Tool to Stress Test it. Im not sure if that is good enough, what should i use to stress test it? Here are my current Clock settings and Temps.
Core: 621 MHz
Memory: 1089 MHz
Temps: 74c (While Stress Testing)
And yesterday i did a big OC on my E6600 (On air) here are the settings:
Clock @: 3.42 GHz
Voltage: 1.55v
Temps (While stress testing w. Orthoes): 53c
Idle Temps: 26c - 30c (My CPU gets hot when i stress test the Ultra because the Ultra is a fireball)
Let me know what you think, or if you have any tips, let me know
::EDIT::
Pictures
[Tagan Black Pearl] [XFX 780i Tri SLi Mobo] [(x2) EVGA 9800 GTX] [Intel Q6600 @ 3.2ghz (Water)] [Corsair 2gb DDR2-800] [(x2) Seagate 500GB HD] [Ultra X3 1000w Modular PSU]
Old December 15, 2007, 10:47 AM
JD JD is offline
As long as you don't see any random pixels on the ATITool cube thingy, then you can keep boosting your video card However, you want to set that drop down box to Performance 3D, not 2D... Overclocking 2D is rather pointless. And if you update to the latest RivaTuner you can overclock the shader too.
Thats a ton of voltage just to get 3.42GHz on your E6600. I can use stock voltage to get that. But your temps are fine so I see no reason to worry.
Old December 15, 2007, 10:52 AM
Hillsdale's Avatar
UPDATE:
Right now im Stress Testing on ATI Tool with these clocks:
Core: 639 MHz
Memory: 1107 MHz
Temps: 75c with random jumps to 76c
Old December 19, 2007, 01:26 PM
Like stated above Try the new Riva now you can Change the Shaders with out having to edit the bios . So you wil have 3 slider bars to play with =) . For a stress test , if you want to know if the card is 100% stable run 3dmark 01 Nature with no title screens looped 25 times . If it does that then it is stable . But if you are just ocing for temp to do bench marksjust keep going till it crashes =)
G92/8800GTS or G80/8800 Ultra 999Virus999 Video Cards 14 January 4, 2008 01:21 PM
AMD RD680 vs. 8800 Ultra! qwerty Rumor Mill 0 November 2, 2007 05:23 AM
2900XT Crossfire vs. 8800 Ultra Cheator Reviews & Articles from the Web 3 July 6, 2007 04:12 PM
8800 Ultra price slashed Babrbarossa Rumor Mill 8 June 9, 2007 03:41 PM
