Old October 1, 2010, 05:16 PM
Default Help from our northern neighbors
I need help with doing a OC with this current setup. I just going to post newegg links, so you can see what it looks like and cooling wise...
Xclio A380BK full ATX w/ 2x 25 CM fans
Gigabyte GA-EP45-UD3P LGA 775 Intel p45 ATX
Intel core 2 quad Q8400 Yorkfield 2.66ghz
XFX Nvidia gtx 260
2x in raid 0 WD caviar blue 250 GB SATA
W7 64bit ultimate
OCZ ModXStream pro 700W PSU
OCZ Reaper HPC 4gb 240pin DDR2 1066
G.Skill 4gb 240 pin ddr2 1066
Case - Newegg.com - XCLIO A380BK Fully Black SECC 1.0mm thickness ATX Full Tower Computer Case
CPU cooling - Newegg.com - XIGMATEK HDT-S963 92mm Rifle CPU Cooler I5 775 AMD compatible
CPU - Newegg.com - Intel Core 2 Quad Q8400 Yorkfield 2.66GHz 4MB L2 Cache LGA 775 95W Quad-Core Processor BX80580Q8400
HDD - Newegg.com - Western Digital Caviar Blue WD2500AAJS 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GPU - Newegg.com - XFX GX260XADJC GeForce GTX 260 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Power - Newegg.com - OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
Ram - Newegg.com - OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2RPR10664GK
Newegg.com - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK
OS - W7 ultimate 64 bit
Mobo - Newegg.com - GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
Ive found a close setup here...
E8400 with GA-EP45-UD3P Help 4.0 OC
Im looking to get my CPU to 3.4ghz at least. Can i use that setup? I also like the way it was written out. Any tips and how to's?
Neighbors House burnt down Jon_di2 Off Topic 11 September 14, 2008 11:31 AM
Gameguru Mania has Battlefield 2142 Northern Strike trailer Supergrover Press Releases & Tech News 0 January 21, 2007 12:11 PM
