Old December 18, 2007, 09:25 PM
mattydies's Avatar
I hope my MoBo gets back soon.
Thank-you to everyone for thier input
Matty
Old December 19, 2007, 09:36 PM
Lot of different temps/voltages on these. I have one of the older ones (L627A) and I can get mine to 3.6Ghz @ 1.5v (BIOS). Temps arent that bad, as I have a TR Ultra Ex. cooling it so it hits 57 under Orthos load. For normal usage I do 3.2 (8x400) @ 1.275v (BIOS), but like everone says, luck of the draw (esp. the newer ones). Good luck and keep us posted.
Old December 21, 2007, 12:03 PM
r0k0's Avatar
with my new bios.. i slapped mine to 3ghz without nothing.. and its stable no crash yet :P and been playing game like crazy haha
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Over Clocking Ram mattydies Overclocking, Tweaking and Benchmarking 12 January 19, 2008 02:59 PM
e6600 using p35 chipset? Shadowmeph CPU's and Motherboards 7 January 7, 2008 10:53 AM
lapped e6600 enaberif Overclocking, Tweaking and Benchmarking 17 October 15, 2007 08:24 PM
e6600 p5b help plz... razor4life CPU's and Motherboards 14 April 7, 2007 12:32 AM
SLI and CrossFire Push Power Supplies to the Limit Gav Troubleshooting 3 February 12, 2007 03:09 PM
