Old September 27, 2010, 11:10 PM
Default OCCT
Just thought I might point out this utility to those of you who might not already know about it. IMO its the holy grail of overclocking, running a GPU test with error scanning enabled definitely gives ur card a run for its money usually hitting temps up to 10 degrees higher than furmark on all components. Also the error scan is good for detecting artifacts and establishing the maximum stable overclock (although the 5 series is apparently immune to artificacts, i still managed to get some during the test).
Theres also CPU testing but I haven't really experimented with that as yet so I'll refrain from commenting.
Anyway, if you want to give it a try, the links below:
Download - OCCT Website english
OCCT Test, 1 error?? bushwickbill Overclocking, Tweaking and Benchmarking 1 April 1, 2010 04:37 AM
OCCT Running at 65%... Realityshift Overclocking, Tweaking and Benchmarking 7 April 22, 2009 01:36 PM
Weird OCCT geokilla Overclocking, Tweaking and Benchmarking 22 April 6, 2009 01:46 PM
Code 4 error on OCCT Gooses Overclocking, Tweaking and Benchmarking 1 September 6, 2008 06:05 PM
OCCT Stable 1/2 Scratch Overclocking, Tweaking and Benchmarking 5 April 13, 2007 03:29 AM
