Old September 25, 2010, 06:57 AM
Default 4 dimmsG.Skill Trident Frequency Problem
Previously i had 4gb with 2 DIMMs and the ram able to clock at its advertised speed of 2133mhz, but i put another set of the ram in and it refuse to register 8gb of ram unless i put the frequency to 1300. I'm using the Asus P7P55D premium mother board. Any advice is appreciated
Old September 25, 2010, 08:31 AM
using more banks takes a toll on the motherboard, but it shouldn't be so much as clocking down to 1300.. trying bumping up voltages a little more. can you not get 1600 or anything? just 1300?
Old September 25, 2010, 12:21 PM
is it the same exact ram(same chips) ? look at the timings.
Old September 30, 2010, 12:31 PM
Thanks for the reply. I actually figured out what is wrong. When you have 4 DIMM it takes a toll on the memory controller. I left the voltage on the RAM to 1.65 but upp the IMC voltage to 1.3 (although intel says 1.21 is the max) and now it runs at 2.2ghz without a problem.
G.Skill's trident LacrosseTown RAM 5 May 29, 2010 10:59 AM
G.Skill Trident 6GB PC3-16000 CL9 Tri Channel Memory Kit Review MAC RAM 17 February 22, 2010 04:21 PM
Help adjusting NB frequency?? aviduser Overclocking, Tweaking and Benchmarking 0 March 21, 2009 06:17 AM
g.skill 64gb ssd raid0 problem Phobia Troubleshooting 0 January 16, 2009 07:55 PM
