Old September 25, 2010, 05:53 AM
Default Couple of quick questions
I just installed a new i7 950 and ran the large FFTs in Prime95 and I'm assuming that the temps are well in line with my, air cooled, overclock?
I'm also assuming that to validate that test it needs to be run for 24 hours?
Also, I'm assuming that it would be a good idea to run the Small FFTs, the blend test, as well as the IntelBurn test?
One other question. From what I've read you want to keep the core temps below 75c?
Old September 25, 2010, 07:26 AM
SmallFFT is better than Large for CPU testing.
Blend is good for testing memory.
I personally don't like IBT but others do.
No one program is 100% capable of making sure a system is stable.
Only F@H does that :P
Old September 25, 2010, 12:20 PM
for maximum stable overclocks yeah, try not to goo too far up. some say keep it under 85, others 75. it depends how much you want to push it.
Couple of questions Lpfan4ever Storage 3 May 20, 2010 12:04 PM
Couple of Questions jcmaz New Builds 12 January 24, 2010 10:04 AM
A couple questions Lpfan4ever Water Cooling 16 March 1, 2009 08:01 PM
RivaTuner,couple of quick questions.....Hardware Monitoring Canadianguy Video Cards 2 December 8, 2007 08:00 PM
Couple questions nasrott CPU's and Motherboards 4 July 12, 2007 02:46 AM
