Old December 11, 2007, 10:19 PM
Level up: 42% Level up: 42% Level up: 42%
Level: 9 - 138 points to level up
Cool Peltiers ?
Hi,
Any of you folks found a store in Canada that sells some modest peltiers, Like 60 watt on 14 or 21 volts? I was thinking of cooling the resivoir down using a couple of them.
The Case has plenty of air blowing around, keeps pretty steady at 26 C , 80 percent load on everything.
Whats your take on this, is it worth it to add them or not?
Old December 12, 2007, 09:06 AM
qwerty's Avatar
Give these guys a look. They are out of Calgary AB
CoolItsystems
Old December 12, 2007, 02:53 PM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
Now... this is something I wouldn't mind trying to cool the liquid down! What A BEAST! Boreas 12 TEC Chiller However @ $ 449....it's a little too expensive!
Prof. Dr. Silver
Old December 12, 2007, 06:33 PM
Babrbarossa's Avatar
Super Moderator
Hmm- if that things works well enough to be worth it, then your water will be cold enough to create condensation on the outside of your waterblocks- I'd like to see a review
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old December 12, 2007, 06:48 PM
werty316's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 11 - 157 points to level up
Not really a review its still neat to see how it fits installed: One part case, one part cooler, eight parts awesome - TheMurph - Maximum PC
Old December 12, 2007, 07:02 PM
MpG's Avatar
MpG MpG is offline
Level up: 62% Level up: 62% Level up: 62%
Level: 15 - 248 points to level up
I wouldn't expect a 60W pelt would do a whole lot, honestly. Maybe compensate for the system's heat dump at idle? And if the pelt was only cooling the reservoir, it's entirely possible that you'd never see sub-ambient temps anywhere near any circuitry.
Of course, that doesn't mean I'd be willing to try it on my system...
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old December 12, 2007, 09:31 PM
Level up: 98% Level up: 98% Level up: 98%
Level: 7 - 4 points to level up
That coolit system comes with a control unit that monitors the temps, doesnt let it get cold enough to produce condensation
Gentlemen, start your spaceheaters.... er Computers.
