Old September 23, 2010, 01:30 AM
Default i7 960....
Any info on bumping up the clocks on these CPU's appreciated,
what works, what doesnt..
anyone have performance figures?
Old September 23, 2010, 01:03 PM
Avid6eek's Avatar
What motherboard are you using? The first thing you'll want to do is set the multiplier to the turbo multiplier if your motherboard supports it. From there it's all about increasing the BCLK, increasing voltages, and keeping your RAM within spec.
Old September 23, 2010, 05:03 PM
hopefully this will shed some light on the system.....
Asus Ramapage extreme III
Kingston 2000 mhz 6 gig DDR3
i7 960
gigabyte 5870
700w coolermaster
1tb seagate
GIGABYTE TOP X58A-UD9 with Intel Core i7 960/980X OC Performance Review windwithme Member Reviews 10 July 5, 2010 07:37 PM
Intel Rolls Out Core i7 960 FiXT Press Releases & Tech News 7 October 20, 2009 06:02 PM
