-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   can't get kingston hyperx to run at 2000mhz (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/36342-cant-get-kingston-hyperx-run-2000mhz.html)
mrbmello September 17, 2010 09:03 PM
Hi All,
I have the Asus p6t deluxe v2
I have no experience with overclocking but would like to get my 6GBs of ram to run at its rated speed of 2000MHz
It is currently running at 500mhz.
System specs:
OS: Windows 7 ultimate 64bit
CPU: Core i7 930 @ stock.
RAM: Kingston HyperX KHX2000C9AD3T1K3/6GX
GPU: 2x 8800 GT in SLI
PSU: Antec 1000w
SSD: OCZ Vertex 2 series 60GBs
Mobo: ASUS P6T Deluxe V2
Just in case it's helpful.
r0bc September 17, 2010 09:40 PM
Did you enable the XPM profile in the BIOS?
LarkStarr September 17, 2010 09:48 PM
check your voltages in the bios! make sure they are spec!
mrbmello September 17, 2010 09:49 PM
Hi r0bc,
Thanks for your reply but i am not familiar with XPM Profile how does one enable it?
mrbmello September 17, 2010 09:56 PM
Hi LarkStarr,
My DRAM Bus Voltage is 1.50 is that spec?
r0bc September 17, 2010 10:00 PM
1 Attachment(s)
Here is a pic I found, hope it helps.
Select XPM and save changes.
mrbmello September 17, 2010 10:06 PM
Hi r0bc,
thanks heaps for the screen shot ill try that now.
mrbmello September 17, 2010 10:18 PM
Hi r0bc,
I do not think my computer liked that to much it crashed after i saved and would not turn on till i removed the battery and put it back in.
r0bc September 17, 2010 11:13 PM
Originally Posted by mrbmello (Post 430345)
Hi r0bc,
Yeah crashes happen but shouldn't need to remove the battery, must be a clear cmos button or at least a jumper somewhere. I'm not familiar with those boards but guaranteed someone on here can help get the ram running at 2000mhz or faster.
r0bc September 17, 2010 11:15 PM
and welcome to the forum
