Old September 15, 2010, 08:04 AM
kruzn4evr's Avatar
Default Furmark testing
Hey guys, I decided it was time to run more Furmark tests now that I have a 2nd PSU hooked up to 2 of the 480's and running on a different curcuit so I don't blow the breaker The main reason for testing isn't so much stability but more to see what temps I hit using the quad rad because I'm trying to decide if I'm going to add a 360 into the mix. Last time I ran Furmark I ran it for just under 30 mins before the breaker popped, if IRC my temps hit a high of approx. 65c on one card and a low of 62c with all 4 OC'd to 870/1740/2000.
My question is, what is a good amount of time to run Furmark?...10, 20, 30 mins?...more? I just ran it for 20 mins at stock settings and temps seem to hit their highest point of 58-59c around the 8 min mark and just cracking 60c a couple of times by the end of 20 mins.
Old September 15, 2010, 12:13 PM
usually after 5-10 minutes the temps tend to stabilize, given everything else does not change, i.e. fan speeds, case temps(open windows in winter) etc. but 30 plus minutes give you a better idea. waste of time,usually, unless you are looking for bugs or such
Old September 15, 2010, 12:16 PM
What exactly are you doing with this computer anyway?
Old September 15, 2010, 12:18 PM
gingerbee's Avatar
gaming lol i only run it for about an hour to see if temps will climb at all
Old September 15, 2010, 12:42 PM
kruzn4evr's Avatar
Thanks dangtx, I figured I was pretty safe with 30 min runs but wasn't sure. Did a 35 min run and everything went off without a hitch, temps topped out at 60c with stock settings and no blown breakers!..lol.
As gingerbee said, mostly gaming in 3D surround along with some benching, hoping to crack 60k in Vantage just for fun
Old September 15, 2010, 12:44 PM
lowfat's Avatar
IF you are just looking for benching clocks 5 minutes would be fine. For gaming I would try 30 minutes or so. If you are looking for folding@home stable clocks, don't bother.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 15, 2010, 01:17 PM
no worries. what i do,lazily, look at the graph. when it doesn't go up noticeably anymore, thats it. if i see over 85c i may get worried, depending on the gpu. good luck with your testing, sir.
Old September 16, 2010, 08:37 PM
rjbarker's Avatar
B
Usually run for about 15 - 20 min ....around the same time I stabilize at 90C .....I find good enough for gaming / benching....P60 eh.....nice
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 16, 2010, 11:07 PM
I would say run a little longer since you're WC'ing, as long as the water temps are rising the temps still may go up. It just might take a lot longer to max out on your loop. Anyways, looks like it's running fine :)
intelburntest + furmark problem ubernoobie O/S's, Drivers & General Software 4 July 1, 2010 03:23 PM
Gallery Testing FiXT Case Mods, Worklog & Gallery 7 June 9, 2010 08:46 AM
FurMark vs GPU Caps - Stress Issue & Temps Surfer_2099 Overclocking, Tweaking and Benchmarking 3 October 23, 2009 08:46 PM
Furmark and SLI BT! Overclocking, Tweaking and Benchmarking 7 March 28, 2009 09:03 PM
[FS] Testing the waters Phobia Buy/Sell & Trade 4 January 16, 2009 07:59 PM
