  #21 (permalink)
Old September 14, 2010, 10:39 PM
burebista's Avatar
Anybody with a Palit or Gainward GTX460 succeeded to install this driver? On my Gainward GTX460 1GB GS GLH I have a rainbow on desktop after a while (it looks like in transition to low power state in 2D but I'm not sure) and after that a hard lock on computer so I must reset it from button.
Tried a clean install/uninstall but no luck.
I'm not alone, on Guru3D I saw two guys (one with Palit and another with same Gainward) with exact symptoms.
Back to 259.47 WHQL and everything is fine. Also 259.47 WHQL it seems the only driver which keeps a low latency on my rig.
If it ain't broke... fix it until it is.
  #22 (permalink)
Old September 17, 2010, 10:30 AM
burebista's Avatar
Yeah, it's a problem with Palit/Gainward GTX460. They're working on BIOS-es (today Gainward throw 2 of them in a couple of hours) but no luck until now.
So I've downloaded an old BIOS, asked a guy to modify my minimum fan speed at 30% and here it is, 260.63 working, dead silent in idle, my VRAM frequency where should it be and DPC Latency all green.
Me very happy.
Geforce Forceware 260.52 leaked Closed Note Overclocking, Tweaking and Benchmarking 7 September 11, 2010 07:31 PM
NVIDIA GeForce Forceware 196.21 WHQL Drivers Released FiXT Press Releases & Tech News 18 January 22, 2010 07:54 PM
NVIDIA GeForce Forceware 190.38 WHQL Drivers fefox O/S's, Drivers & General Software 17 August 2, 2009 03:26 PM
Forceware 190.40 - beta MittWaffle O/S's, Drivers & General Software 1 July 28, 2009 12:10 PM
Forceware 177.39 leaked beta driver da_bradler O/S's, Drivers & General Software 0 June 24, 2008 11:18 PM
