Old December 9, 2007, 03:10 PM
FritzGuy's Avatar
Level up: 6% Level up: 6% Level up: 6%
Level: 7 - 130 points to level up
Default Problems with overclock
Hello fellow Canucks,
This is my first post on this great site, I have been following this site for a bit.
My issue is overclocking my P5W-DH Deluxe Mobo with an E2180 2.0 Gig CPU and 4 Gigs of OCZ Reaper PC26400 with stock timings of 4-4-4-15 along with an EVGA 8800 GT (KO)...right now I have my CPU at 3Gigs at 1.25V, if I try to bring it up to 3.4Gigs at 1.425v my system won't even boot, would love to get it at 3.6 Gigs but Bios ver 2301 will not even let me add a small amount to my MCH or RAM voltage, the increments are way to big. I have read all the info on Overclockers.net but it seems to just address the E6600 and my chanche to get one fell though :(...so I am asking any gurus here if the can give my any advice to get this highly overclockable CPU to give me more juice.
Many thanks
Old December 9, 2007, 06:56 PM
3.0charlie's Avatar
What's your CPU cooling?
1.425V for 3.4 may not be enough. You need to set the volts higher.
Loosen the Ram timings to 5-5-5-18, 2.1V and try again.
Watch those CPU temps, threshold is the usual 60C under load.
John
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old December 9, 2007, 07:11 PM
MpG's Avatar
MpG MpG is offline
Level up: 62% Level up: 62% Level up: 62%
Level: 15 - 248 points to level up
This CPU seems to have a high sample variance. Some will hit high 3'sm while others seem to struggle to stay stable at 3.0 GHz.
What's your FSB:RAM ratio? Make sure you pull it down to 1:1 while you're trying to find the CPU's limit.
You're using that chip's 10x multiplier, right? Have you tried a higher FSB and lower multipliers? The board/chip might have a FSB hole in the low 300's. You might consider pulling the FSB into the high 300's, lowering the multiplier as necessary.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old December 10, 2007, 04:05 PM
FritzGuy's Avatar
Thanks for your input..mind telling me if this seems pretty good ?
Old December 10, 2007, 04:11 PM
3.0charlie's Avatar
Can you resize them? They're just too small. Also, HWC has its own image host server, located at Vb Image Host.
Old December 10, 2007, 05:03 PM
FritzGuy's Avatar
changed resolution of pictures
Old December 10, 2007, 07:14 PM
3.0charlie's Avatar
Looking really good! Temps are fine under load, for 3.0GHz. But if you really want to push it, you need to change some of your settings. Like MpG stated, try the 9x multi instead of the 10x. Start at 300 FSB, raising slowly up to 380 FSB. That will give you 3.42 GHz. Also change your ram timings to 5-5-5-18-32 (really loose timings) to remove the Ram from the oc equation. Once the CPU oc is complete, you can then work on the Ram timings.
What's your CPU cooler? Cause' you'll have to watch those CPU temps since you will have to raise the Vcore to reach those speeds, if you do reach those. OC'ing is a hit-and-miss affair.
You can even try a 8x multi, looking for 425 FSB (feasible on a lot of boards).
John
Help me Overclock my Firestix. Dethredic Overclocking, Tweaking and Benchmarking 11 November 9, 2007 10:15 AM
8800 GTS 320 MB overclock belgolas Video Cards 2 September 21, 2007 06:52 PM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 05:32 PM
Oldschool overclock Babrbarossa Overclocking, Tweaking and Benchmarking 4 February 21, 2007 06:16 PM
