Old September 5, 2010, 06:13 PM
Jackquelegs's Avatar
Default My first run at OCing the i7 930
CPU-Z Validator 3.1
Right now I'm trying it at these settings. Any advice would be appreciated, since this is my first time playing with this platform
Iapetos
Zephyranthes
Old September 5, 2010, 07:34 PM
rjbarker's Avatar
Your LinX window shows nothing at all? How many cycles tested? Nice OC with low vCore btw.....
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 5, 2010, 07:37 PM
It has been testing for a while now actually, that was taken when I started testing
Thanks, I think 1.275v is the lowest it'll go...1.25v poops out
Iapetos
Zephyranthes
Old September 6, 2010, 06:54 AM
Coach's Avatar
Compared to my i7 920 D0 that is a super low vcore. I am 1.36v at 4.2GHz with HT on... nice chip you have there!
Old September 6, 2010, 07:07 AM
stoanee's Avatar
How are temps?
heatware
Old September 6, 2010, 09:46 AM
~ 68C load average across 4 cores with HT on
Iapetos
Zephyranthes
Old September 6, 2010, 09:52 AM
stoanee's Avatar
Darn nice, what cooler?
heatware
Old September 6, 2010, 09:54 AM
WC'ed with Supreme HF and PA120.3
Iapetos
Zephyranthes
Old September 6, 2010, 11:34 AM
JD JD is offline
Can't you bump that multi up some more? I run my 920 D0 at 21x...
Old September 6, 2010, 11:58 AM
gingerbee's Avatar
it's at 21
i7 930 Help! soulicro Overclocking, Tweaking and Benchmarking 3 August 10, 2010 01:32 PM
Anyone had this i7 930 batch yet? Jelah Overclocking, Tweaking and Benchmarking 13 August 9, 2010 05:17 PM
i7 920 or 930 phoenixrage Overclocking, Tweaking and Benchmarking 16 June 7, 2010 02:21 PM
Frustration OCing Pentium D 930 Forsaken502 Overclocking, Tweaking and Benchmarking 1 May 5, 2007 05:04 AM
