Old September 4, 2010, 06:07 PM
Default overclocking i7 860
This is my first time ever overclocking anything and just wanted some opinion on how it looks
im at 3.8ghz
mulit-21 blclocl 181 ram is at 1448
cpu volt is 2.87
imc/vtt 1.2
i got 8 gigs of corsair dominator memory
i just feel like the cpu volt is a little high for 3.8 ghz bit i cant run prime for more then an hour with any lower cpu volts, also have hyperthreading on and all power saving off. any tips/comments would be apreciated?
Old September 4, 2010, 06:20 PM
That is really high. What are your temps like?
Old September 4, 2010, 07:44 PM
Fudd Rucker's Avatar
With a noctua i was able to get my i7 860 to 4ghz stable - 200x 20. 1.35v , 1.25vtt,1.65 ram. Temps were in the high 70s on a noctua heatsink i was using.
I couldnt think of something snarky or interesting to put here this time around.
Old September 4, 2010, 09:10 PM
Check your CPU voltage again, because it's definitely not 2.87V. Your motherboard isn't even capable of supplying that much voltage to the CPU.
Old September 4, 2010, 09:36 PM
drop everest in there and check temps, voltages(not accurate if the mobo reads them wrong).
im thinking 1.28 volts?
Old September 5, 2010, 12:47 PM
LOL haha so sry bad typo there i meant 1.28 volts and my temps after about 4 hours of prime are around the low 70s
Old September 5, 2010, 12:54 PM
That sounds good to me. Have you tried going up to 4GHz?
Old September 6, 2010, 04:14 PM
I hvnt tried for 4 yet cause my temps were hitting the low 80s at 3.8 and i dont really wanna push the temps much higher then that
Old September 8, 2010, 08:10 AM
Rison's Avatar
Mid to High 70s is where I like to keep my i7 860s.. I have my two @ 3.6Ghz and 4.0Ghz. One with CM 212+ and other with Corsair H50.
1.28v isn't too bad.. min are at 1.26v (3.6Ghz) and 1.36v (4.0Ghz)
Going from 3.6Ghz to 4.0Ghz takes a lot more voltage (some have to run at 1.4v to keep it stable) and creates a lot more heat.
What cooler are you using?
I'll learn to manage my anger, when people learn to manage their stupid.
[WTB] I7 860 quikgp Buy/Sell & Trade 1 July 14, 2010 10:26 AM
New i7 860 Overclocking flightsimnerd Overclocking, Tweaking and Benchmarking 12 February 15, 2010 09:11 AM
I7 - 860???? Recker New Builds 3 December 6, 2009 08:24 PM
i7-860 Overclocking anthonee1230 Overclocking, Tweaking and Benchmarking 6 November 28, 2009 06:09 AM
I7 860 martin_metal_88 Overclocking, Tweaking and Benchmarking 5 November 6, 2009 10:37 AM
