Old September 1, 2010, 06:56 PM
Default Cooler to overclock a 1055t
hello i recently bought an amd 1055t 6 core cpu and i will be overclocking it to atleast 3.8 on my asus ASUS M4N98TD EVO.
i just have no idea about which cpu cooler i need.... will a cm 212+ work? or i need a better one?
Old September 1, 2010, 07:07 PM
JD JD is offline
CM 212+ should work very nicely. Can't go wrong for the price anyhow.
Old September 1, 2010, 07:11 PM
I use a zalman 9700n,keeps my amd 945@ 3.39(i know thats nothing big but i get the best performance in benchmarks with it)load @ 41C and idles @ 23C
thast the minimum you should look at, also thats the best cooling/dollar spent right now, given you buy it in canada. other countries are probably way more expensive.
Old September 1, 2010, 07:31 PM
but the 212+ costs only 30$ .... i was thinking on spending 60ish$ on a cooler..... whats the best i can get
Old September 1, 2010, 07:59 PM
check the review for the v6 gt that ak did a couple days ago. thats 60 bucks. beats the 212+ with a decent 10c in some cases.
Old September 2, 2010, 03:42 AM
Closed Note's Avatar
Prolimatech Megahalems in a Push/Pull Configuration.
Old September 2, 2010, 04:41 AM
lol.. stock.
that's what I'm doing.
Temps are slightly toasty, but nothing dangerous or wild.
1055T Temps not showing Nerdy Troubleshooting 13 August 10, 2010 03:11 PM
1055T X6 only 2 cores! Black_Ice-Dragon CPU's and Motherboards 19 July 4, 2010 06:05 PM
1055T or i7 920? (EDIT - went with LGA1156 setup) Fracture New Builds 13 May 23, 2010 06:12 PM
AMD 955 or 1055T? jcmaz CPU's and Motherboards 7 May 17, 2010 07:55 AM
