Old December 6, 2007, 01:30 PM
Default Problems Overclocking with Gigabyte GA-P35-DS3L
When I try to OC my mobo, it reboots and just defaults back to original settings in the BIOS. This board is driving me crazy. I went out and bought a Thermalright Ultra 120 Extreme and it sits in the box mocking me because I can't OC. Dark times, my friends. Any help is appreciated. What kind of M.I.T. settings are you people using to OC if you have this board? I'm using F6 BIOS, but I see F7 is out now.
Thanks,
Rick
Intel Core 2 Duo E6750 @ 2.67 GHz
Patriot 2 x 1 GB DDR2 PDC22G6400LLK dual channel
ATI X1950 PRO 256 MB DDR3
Enermax FMA II EG465P-VE 460W
Creative Audigy 2 Value
Old December 6, 2007, 01:37 PM
donimo's Avatar
Thanks,
Rick
I have the identical system to yours, except for ram, I have only tried out the CIA auto overclock so far, just for fun, it got up to 3.26ghz and 980 on the RAM with no issues whatsoever...
orthos for 4 hours stable.
it is kinda finicky when I was playing with ram though...
Mobo MA770-UD3P CPU 7750BE RAM:4x1GB OCZ Gold GPU:XFX HD6850 Black Edition @820/4400MHz Case: Antec Sonata III PS: Corsair HX620
Old December 6, 2007, 01:44 PM
3.0charlie's Avatar
Thanks,
Rick
What oc are you trying to reach exactly and what are your settings? I have that board and actually it was the easiest oc I have ever done. See sig.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old December 6, 2007, 05:13 PM
Delavan's Avatar
Although I don't have this particular board, I remember that there is a particularity about how to save your settings. If you miss that step, the board will reset to default.
I thinks it's something about rebooting and pressing an F key to testify that the settings are what you want them to be.
Sorry to be clear as mud,
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Gskill RIPJAWS X / 2 x N560GTX Ti Twin FROZR II OC in SLI (8700 3Dmarks11 P-score)
Old December 7, 2007, 06:55 AM
I'm just trying to get a 3.2 GHz OC. FSB is 400. If anyone is OCing with this board and has C2D 6x50 CPU, please share your BIOS settings so I can try and make some headway here. Thanks.
Old December 7, 2007, 07:16 AM
3.0charlie's Avatar
FSB 400 is feasible with the board, providing the proper amount of volts. What is the highest stable oc you managed? And what were the settings? We'll start from that.
Old December 7, 2007, 09:25 AM
donimo's Avatar
FSB 400 may not require a bump in voltage, with a 6750 it is running at 333 anyways...
Old December 13, 2007, 05:03 PM
Here are my bios shots. I'm using the DS3L with an E6750..
ImageShack - Hosting :: e6750biosshot2yj4.jpg
ImageShack - Hosting :: e6750biosshot1ed0.jpg
Here is the inside of my case.. nothing fancy .. just neat and tidy :)
Antec P182 case.. Trupower 650 psu.. lots of 120mm fans (6 total) wiring routed behind the motherboard (mostly)
ImageShack - Hosting :: img2332jr2.jpg
CPU Cooler (Thermaltake Duorb)
ImageShack - Hosting :: img2330pm1.jpg
And my Overclock results from stock up to my end result (nothing crazy) but a nice jump 4670 stock to 5891 oc'd Video card is an XFX 7900 GS (600 core / 900 memory)
ImageShack - Hosting :: 3dmark2006ocresultscompcz4.jpg
Old December 13, 2007, 05:35 PM
sswilson's Avatar
If my experience with the DQ6 is any indication, the first place I'd be looking is the memory. Make sure you've got the "divider" set as low as possible before trying any OC of the CPU. Mem OC can come after you've found the max of your CPU.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Gigabyte GA-P35-DS3L Northbridge? Evilyeti CPU's and Motherboards 9 April 26, 2008 03:11 AM
Problems with Overclocking my e8400 Tumdace Overclocking, Tweaking and Benchmarking 66 March 12, 2008 02:44 AM
Gigabyte GA-P35-DS3L and G.Skill RAM Supertrash CPU's and Motherboards 3 February 21, 2008 02:40 PM
Reviewer Tryouts: Gigabyte DS3L & Intel C2D E4400 Zertz Member Reviews 17 January 23, 2008 09:27 PM
Problems Overclocking. Dethredic Video Cards 6 November 3, 2007 08:06 AM
