Old August 30, 2010, 02:26 PM
Closed Note's Avatar
Default Overclockin i7 930 Batch #3942A819
Hello everyone.
So I finally gathered and assembled all the parts. Played a little BC2 and did a few Benchmarks to warm up my rig a little.
Now I got curious and started overclocking the CPU, which is currently idling at 45-50C. Is this ok?
I didn't bother oc'ing the GPU since it's already at 80-90C on load. Not gonna touch that until I got it watercooled.
I'm a little phobic, so every feedback is greatly appreciated, since this is my first OC ..
Edit: just run Prime95, 80-90C on load.
Edit: holy s*** it just humped the 100C xD brb lowering settings.
Old August 30, 2010, 02:35 PM
Is that the lowest stable voltage? Try 1.30V with LLC enabled, should hopefully bring down temps quite a bit. What is your QPI voltage?
heatware
Old August 30, 2010, 02:39 PM
QPI is at 1.1V
I'll try that out what you said.
Edit: Temps dropped by 2-5C. The System was 'stable' actually, but hitting 100C on the CPU .. it was just a matter of time until it'd shutdown from overheating xD
Edit: Temps are staying at 69-75C on load now, thank you ^^ Testing it with Prime now ..
Old August 30, 2010, 02:58 PM
Sagath's Avatar
Originally Posted by Closed Note View Post
QPI is at 1.1V
Nice chip! 4ghz at 1.25 on load is a decent D0. You can always keep finding a stable OC, then lower the voltages in increments until you get a BSOD. After that, bump your Vcore by two increments and you should be good to go.
I would still highly recommend atleast a better air cooler, even if you're at 75c on the stock cooler. Ambient Case temps play hell with the stock Intel coolers. I despise them.
Old August 30, 2010, 03:15 PM
thank you very much for the tips :) I can really need them right now ^^
it's not a stock cooler btw. it's a V10. I haven't even touched the stock cooler yet haha xD
btw. I find confusing answers on HyperThreading, should I enable or disable it?
Old August 30, 2010, 03:29 PM
was looking in your system pecs and didnt notice a nice little cm 212+ or such in there.
temps , that stock right? are pretty warm. around 100c itll throttle itlsef.
im blind. v10? hmm...Cooler Master V10 Review Page 4 - Testing - Overclockers Club
Thermolab Intel Heatsink Temperature Comparisons - BADA2010 FrostyTech Review
look in that link for a general heat sink comparison. check the 212+ vs other more expensive coolers.
edit : since you paid for a cpu with ht do enable it.
Old August 30, 2010, 03:31 PM
Sagath's Avatar
Enable HT. It gives you 8 'cores', and will allow for better performance in thread-optimized applications. It will probably raise your coretemp by 3-5c however.
Generally speaking it is good to use!
Old August 30, 2010, 03:40 PM
@_dangtx_: I don't quite understand what you're trying to say ^^; there's a V10 on my 930 right now, with ThermalFusion 400 (which came with the V10)
@Sagath: Thank you, I'll leave it on then if it's just those 3-5C
I'm gonna run a few loops on Linx and Prime now.
Edit: Do I have to look at the Core Temps or the Temp on the left?
Core 1 80C
Core 2 78C
Core 3 78C
Core 4 74C
and on the left it says 67C, I'm a little confused here :o
Edit: haha just had a blackout xD yay this is fun :D I was lucky that my iPad was still on, or I wouldn't have seen s***.
Old August 30, 2010, 04:26 PM
Keep an Eye on all the cores temps.
At least i always have.
Old August 30, 2010, 04:51 PM
yeah,sorry about that.
look here for a better cooler : Cooler Master Hyper 212 Plus CPU Cooler Review
although now that i look at a direct comparison, not worth it. youll probably need a more hardcore cooler, which properly installed will drop another good 5-10c.
Anyone had this i7 930 batch yet? Jelah Overclocking, Tweaking and Benchmarking 13 August 9, 2010 05:17 PM
Core I7 Batch# Saterial CPU's and Motherboards 4 July 3, 2009 09:52 AM
Could people put their core i7 batch number and overclocks here. sheepdogexpress CPU's and Motherboards 8 January 16, 2009 04:10 PM
batch numbers Rapid-X Overclocking, Tweaking and Benchmarking 8 May 12, 2008 10:29 PM
Intel Batch Codes enaberif CPU's and Motherboards 2 February 14, 2008 11:56 AM
