Old August 30, 2010, 05:24 PM
Originally Posted by _dangtx_ View Post
look here for a better cooler : Cooler Master Hyper 212 Plus CPU Cooler Review
That's not a better cooler.
Old August 31, 2010, 01:42 AM
Closed Note's Avatar
unfortunately I couldn't stabilize the 4GHz, I'm currently at 3.8GHz at 1.25 Vcore Volt (120 Linx Runs, 1h of Prime, looks pretty stable right now, but I'll run another few hours of prime.). I'll post the other voltages after work!
Edit: I think I'll stay at 3.8 until I connected all the exhaust fans of my HAF X, currently only one is running, which is the front intake fan. Still waiting for my sleeved cables to arrive from performance-pcs =/ the last time I tried to connect the rear exhaust fan, it caused a blackout on basement level when I plugged the powercable back in hahaha xD
Old August 31, 2010, 08:57 AM
I'm sure you can stably hit 4GHz with a bit more VTT and Vcore.
Old August 31, 2010, 09:16 AM
Rison's Avatar
HT doesn't enable 4 cores, it enables 8 threads. (two threads per core)
I am not familiar with the V10 cooler, however I would recommend getting a higher end cooler if you're running higher voltages / clocking to 4.0Ghz. Noctua D14, Prolimatech Megahalems, Thermalright Venomous X (etc)
I kinda question what's up with the 1.5KW PSU - are you going tri/quad-SLI with those 480s or something? (you should read up on dual vs tri and quad SLI with the 480s before you waste the money for 5-12% performance improvement)
I'll learn to manage my anger, when people learn to manage their stupid.
Old August 31, 2010, 09:48 AM
I'm going quad SLI with the hope that scaling will improve in the next few driver releases, until then I'll go dual or tri-SLI and stay there for a while :)
Thank you for the CPU cooler suggestions!
@Zero82z: I'll try again as soon as I connected all the casefans :) until then I'll stick to my 3.8GHz
Old August 31, 2010, 11:41 AM
Sagath's Avatar
Seriously, you had to clarify this? There is a reason I put cores in brackets.
And last I checked, according to the OS, it views the 'threads' as 'cores, and treats them as such. Thus, technically, they are 'cores', even if they arnt physically 'cores' on the die.
Old September 1, 2010, 03:08 PM
I think I stabilized it .. 3999.9 MHz at 1.247V it says in E-LEET. Just a little more finetuning, and I'm there :)
I'm currently running my routine Linx Loops, and tomorrow I'll fire up Prime for a few hours.
Load Temps are at 80C, max it hit until now is 85C. (I still don't have my exhaust fans connected, I'm pretty sure it'll drop a few more degrees with those connected) Ambient Temp: 18-20C
edit: Crashed on the 50th run :( raised VTT now.
Old September 3, 2010, 01:25 PM
stabilized it at 4126.6 MHz, with HT off.
I created 2 profiles in the BIOS, if I should ever need HT, I'll just fire up the other profile in BIOS.
The temps you see below are on load.
LLC/VDroop is also disabled. Seems like I don't need it to stabilize - lower Vcore = yay for me! ^^
Anyone had this i7 930 batch yet? Jelah Overclocking, Tweaking and Benchmarking 13 August 9, 2010 05:17 PM
Core I7 Batch# Saterial CPU's and Motherboards 4 July 3, 2009 09:52 AM
Could people put their core i7 batch number and overclocks here. sheepdogexpress CPU's and Motherboards 8 January 16, 2009 04:10 PM
batch numbers Rapid-X Overclocking, Tweaking and Benchmarking 8 May 12, 2008 10:29 PM
Intel Batch Codes enaberif CPU's and Motherboards 2 February 14, 2008 11:56 AM
