Old December 5, 2007, 08:59 AM
Question New to OC and buying a new system... need advice
Hi everyone, this is my first post but I've been lurking for a while.
I'm about to splurge $1300 for a new system next week and I still have a few question for the amazingly knowledgeable people here. After a lot of reading, here's what I tentatively settled on:
Asus P5K-E/WIFI-AP motherboard
Intel Core 2 Duo E6750 CPU
Thermalright ULTRA-120 Extreme 6 Heatsink
2 120mm Fans push/pull for the heatsink (What should I get?)
2x2GB 1066 DDR2 RAM (Whatever's on special next week I guess)
Antec p182 case
Silverstone Element ST50EF-PLUS 500W PSU
Geforce 8800 GTS (G92) Vid card
I have a few questions about this setup. First of all, which fan should I get for the heatsink? The Scythe S-FLEX SFF21F seems to be a popular choice, due to longevity, but I recall reading a post by SKYMTL this week on NCIX (can't seem to find it now, SKYMTL posts WAY too much ) that some other fan was a better choice?
Also, for the RAM, will I have any problem getting it to POST at standard voltage? I'm asking because I'm running a system with DDR1 RAM right now, and I don't have a cheap DDR2 module to POST with to change the voltage.
As for the power supply, is this one going to be able to power my overclocked CPU & a G92 8800GTS (single) fine? I chose this one for the stellar review SKYMTL gave it a while ago, as well as the incredibly long cables to help with the p182 cable management. For under $100, could I get something better?
One final question, is it safe to OC the cpu to 3.4Ghz+ for 24/7 operation? I want to leave my computer on all the time. Any special consideration for it? Should I buy extra cooling for the north bridge or such?
Thanks for your input!
Old December 5, 2007, 09:18 AM
3.0charlie's Avatar
Welcome to the forums!
I don't see any problem using the Scythe fans on the HSF; they perform just fine. For the ram, I never, ever had any issues related to the default voltage. As for the PSU, I would personally go for a more powerful model (CPU oc'ed, high-performance VGA, how many HDDs?). I could be wrong though. The Silverstone may be enough.
You can oc 24/7 no problem, as long as your temps are stabilized and that you have good cooling for all components (ram, NB and SB). And since it will be operational 24/7, I would invest in a UPS to protect your system (I have 3 rigs running 24/7 folding, all protected by a UPS).
John
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old December 5, 2007, 11:06 AM
Although these can never be 100% accurate, I like to refer to computer wattage calculators to get a general idea of the draw on my system for when I'm gauging the size of psu I need.
The site I like to use is here and it is pretty up to date on almost all the components. It's really easy to use - click what fits and off you go.
Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900.
Intel E1xxx & E2xxx OC Thread
Old December 5, 2007, 11:21 AM
Hmm, it gives me 360W so I should be good with that 500W.
Buying New Ram: OCZ vs Corsair tgraszat14 RAM 2 February 5, 2008 11:27 AM
Advice for new system for digital artist. Milt CPU's and Motherboards 25 December 26, 2007 02:56 PM
RAM Question - Buying Tonight (09/26/07) - Kandorf RAM 22 October 26, 2007 09:28 PM
Video Card Buying Guide Babrbarossa Video Cards 16 June 19, 2007 08:54 PM
