Old August 25, 2010, 12:08 AM
Default Can't get RAM running with 2000Mhz without high QPI
Hi!
I have been trying to get the RAM running at its designed speed for quite a few days now without much luck.
My setup is:
F3-16000CL9T-6GBRH (2Gx3) 6GB
Asus P6X58D-E (Latest BIOS)
i930
Corsair HX750
F3-Spinpoint 1TB
XFX - 5870
Noctua U12P-SE2
I managed to get my system running for 6 hours after i had to abort with standard clock and XMP profile for the memory if i adjust the QPI to 1.5.
It seems very high. Is this out of your guys experience "normal" and within the norm ?
My temps where in the 80's. The guy from my local shop said thats far way to high, you should be under 60 (Sounds a bit low to me )
It pushes my heat already up a fair bit having the QPI that high so i won't be able to overclock the CPU too much with these settings.
I also managed to get it overclocked to 4Ghz with the ram running at close to 1700 Mhz with the temps beeing 76-77C with CPU and QPI at 1.35
I haven't tried the combination of both but i am a bit worried about the temps.
What is a good temp to run 24/7 id i wanna keep it for 3-5 years ?
Are these temps normal with a good Air Cooler?
RAM not running at right speed Vegas RAM 16 May 31, 2010 02:02 PM
[FS] MSI Wind U100 (2gb ram) with 3 and 6-Cell Battery (Running OSX 10.6) - $260 RLP06 Buy/Sell & Trade 7 March 18, 2010 08:03 AM
Running out of ram in Crysis canmx120 Troubleshooting 11 October 25, 2009 10:02 PM
Anyone running 8GB of Ram in the P5Q-Pro? Issues? The MAX RAM 7 February 10, 2009 08:19 PM
Running RAM 1:1 still the best? biff RAM 12 January 29, 2008 07:30 AM
