Originally Posted by SRwebSEO Hi,
I'm not sure why SpeedStep is an issue here as in standby/shut down the whole computer is turned off and only standby current is provided from the powersupply. I would have the thought the powersupply compatibility warning is due to the way the CPU with SpeedStep enabled quickly causes extra power to be drawn when required and some powersupplies may not be able to react quick enough, I would have thought that all branded new powersupplies are just fine. |
Your post makes absolutely no sense and has nothing to do with the issue at hand.
