Old December 4, 2007, 08:24 PM
MpG's Avatar
MpG MpG is offline
This article by X-bit might be worth looking at. It's not your exact board, but it's very similar, and on one page, they go into detail on how they overclocked it, including voltages and weak points that they found while OCing a quad-core.
Old December 5, 2007, 04:42 AM
3.0charlie's Avatar
Originally Posted by Kessler View Post
It's been stable for 2 hours in orthos @ 3.4 Ghz ( 8x 425 ).
You're getting there, slowly but surely. But why the 8x multi? The Q6600 has a 9x default multi.
You might be hitting your board's FSB wall. Try upping the multi to 9x, and drop the FSB the 400.
John
Old December 5, 2007, 06:02 AM
By the way what is your batch number?
If you had your batch number you can look up what other people have been getting with it.
I personally would go up to 1.45 or so voltage for 24/7 use.
less than 63C for max load to me is fine.
Old December 5, 2007, 01:52 PM
John
Well I tried setting 9x 378 and it didn't work...
I read a bit of the article on xbitlabs and searched Asus Maximus Formula overclocking on Google.
I've been able to raise the vcore and ram voltage but when I set 1.4325v in the bios it shows 1.400v in CPU-Z! Which one is correct?
Also is there any program to see the current ram voltage?
Old December 5, 2007, 04:59 PM
3.0charlie's Avatar
There are no reliable software to monitor voltages. Can't hit 9x378? But 8x425 works. I'm surprised, but keep on playing with the BIOS settings and you may hit 8x450. Or 9x400.
Old December 5, 2007, 05:09 PM
Babrbarossa's Avatar
If you're just going for the max OC for bragging rights and some benches- giver 'er some more voltage- if the load temps are only 55, you have another ten degrees to play with- although, I found that nothing beyond 1.45 helped my q6600 OC (think I might need to reseat my waterblock)
psst, wanna see my binder?
Overclocking my BFG8800GT dtownbrown Overclocking, Tweaking and Benchmarking 10 March 9, 2008 11:32 AM
Overclocking 2900XT Varroa Video Cards 1 February 25, 2008 05:27 PM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 27, 2008 11:05 PM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 11:28 AM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
