-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Low Vantage Score... (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/35450-low-vantage-score.html)
fjanicki August 21, 2010 05:30 PM
Hey,
I have had this system for about a year and a half and recently build a new system for someone and benchmarked it and decided to benchmark mine just for the sake of it and realized that my score seems to be fairly low.
Is there anything I could do, wrong bios settings perhaps? Because it looks like the i7 should perform a lot better than this according to different 3dmark benchmarks I saw. I know that the 4870 is not that good anymore, and I will upgrade when th 6xxxx comes out but other than upgrading my GPU, what's wrong with my system?
Info from 3Dmark vantage: CPU Info Physical proces - System Info from 3dmark Vantage - ukGeRyPw - Pastebin.com
System spec, in images!
http://i33.tinypic.com/seu4o3.png
http://i34.tinypic.com/1z9aop.png
http://i35.tinypic.com/fualz.png
http://i33.tinypic.com/xgk6le.png
http://i34.tinypic.com/55qb2q.png
http://i37.tinypic.com/33cb1v8.gif
JD August 21, 2010 08:16 PM
That score is perfectly fine for a HD4870...
My HD4890 w/ Core 2 Quad was about the same:
http://i85.photobucket.com/albums/k7...age-p-4890.png
And your CPU score is perfectly fine too, here's my i7 920:
http://i85.photobucket.com/albums/k7...0-10501300.png
So really, nothing to worry about. It's all good.
Closed Note August 22, 2010 04:52 AM
If you have an aftermarket cpu cooler, I suggest you overclock your cpu and push it towards 4GHz.
fjanicki August 22, 2010 07:29 AM
Yeah I have the xigmatek hdt-s1283
I recently bumped it to ~3.4 GHz, I might just push it higher for the sake of it.
fjanicki August 22, 2010 08:19 AM
And also, the new build I built recently scored
CPU: 31483
GPU: 12011
Total: P14208
How come that a Phenom II x2 550 (90$) scores 50% higher than a i7 920 (350$) ?
System specs: http://www.hardwarecanucks.com/forum...amd-build.html
JD August 22, 2010 08:54 AM
CPU: 31483
GPU: 12011
Total: P14208
You used a GTX460 right? It has PhysX support which Vantage uses and thus skews the score a ton. Re-run Vantage, but go into the options and uncheck PPU or open the NVIDIA Control Panel and disable PhysX.
Once that's off, I'm sure it'll score quite a bit less.
fjanicki August 22, 2010 09:27 AM
Oh I see, I'll try that when I go back to his place eventually.
rjbarker August 22, 2010 09:38 AM
You should be able to run that I7 @ 3.8 Ghz without much effort at all. Bump it up man....
gingerbee August 22, 2010 10:14 AM
but that score is fine for 4870 i have one
BrianHanna August 22, 2010 01:00 PM
that score is normal, my non oeverclocked 4870 (the HIS) gets 9700
