<~----> Problems with my 4870s? - Hardware Canucks
Old August 18, 2010, 06:13 PM
BrianHanna's Avatar
Default Problems with my 4870s?
I have an HIS 4870 1gb and a XFX 4870 1gb, lately, at least in sc2, i have been getting artifacting, i was using 10.6 drivers, now i am on 10.7 (havent tested it yet), my cards are at stock settings.
My case is a haf 932 as my case, which has plenty fans, my cpu, overclocked at 4.2 has idle temps of 32 degrees, but my cards idle at 46 or so, and im sure that's fine, but if it isnt overclocking, and it isnt heat, whats with my cards doing this?
it also started happening with dragon age origins a few weeks ago, but ignored it since that's the only game it happened in, and i stopped playing it since i beat it, but i am worried that i am now seeing it with Sc2.
hopefully it was a driver issue and it wont happen again, but if it isn't, i really can't afford another gfx card atm.
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old August 18, 2010, 06:20 PM
furmark each alone, or 3dmark loop each. see which is bad.
Old August 18, 2010, 06:42 PM
BrianHanna's Avatar
yea, ill' do that.
Old August 18, 2010, 06:49 PM
also do swap slots, just in case. if each alone works fine,...in both slots? drivers/software or maybe psu? but that would be the least i think
you got room for two more.
Old August 18, 2010, 06:51 PM
BrianHanna's Avatar
nah, i doubt it's the PSU
Old August 19, 2010, 01:09 AM
try out the 10.7's before anything. they helped overall with my sc2 performance on my 4890.
else pop one out as dan says and stress it up.
Old August 19, 2010, 02:39 PM
BrianHanna's Avatar
Vantage scores.
both cards (xfx top, HIS bottom) 14011
xfx top slot 9576
HIS bottom slot 9583
i tried putting the HIS on the top slot, but it wasn't recognized? the resolution was 800x600 and i couldnt put it to 1680x1050, could be a driver issue?
going to try put the XFX on the bottom now, could it just be an issue with sc2?
Old August 19, 2010, 02:58 PM
possibly.
ok so bench didnt borke. furmark?
Old August 19, 2010, 03:07 PM
BrianHanna's Avatar
Originally Posted by _dangtx_ View Post
possibly.
those were futuremark scores
Old August 19, 2010, 03:11 PM
Futuremark vs FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
but if it passes vantage without any issue, i guess theyre ok hardware wise.
XFX 4870s in the future? Jonwall Rumor Mill 24 December 27, 2008 09:13 AM
When are Canadians getting the cheap 4870s? AERo Video Cards 15 December 9, 2008 07:10 PM
new pc problems... tzetsin Troubleshooting 12 May 17, 2008 08:17 AM
Help Please (2 problems) AnthraxAdrian Troubleshooting 20 April 27, 2008 11:34 AM
having problems slisgrinder Overclocking, Tweaking and Benchmarking 2 April 14, 2008 06:47 PM
