Old December 2, 2007, 01:59 PM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Default Bad overclock settings?
FSB strap and PLL voltage on AUTO?
I have an ASUS P35 board+333stock FSB cpu. Bios is pretty much the same for them.
Does anyone ever leave the PLL voltage to AUTO when ocing? Manual options are 1.5-1.8.
DRAM frequency-set to 667, with an FSB of 400 it translates as DDR2 800 (1:1) in cpuz.
I have a FSB strap option on AUTO, but would like to know if I should use a manual setting?
Ive also DISABLED? Bad idea?
C1E support
Max CPUID limit
Vanderpool technology
CPU TM function
Execute disable bit, PECI.
I don’t want to do any damage just yet and am just trying to get a feel for this new setup. Any advice would be greatly appreciated.. I was using this OC guide to help with adjustments
http://forums.hexus.net/hexus-hardwa...s-p5k-add.html
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
Samsung 216BW settings? jasonmoreau Display Units 2 January 22, 2008 03:55 PM
Setting XFI Card and Ultra High Settings in BF2... Canadianguy Audio 10 December 4, 2007 10:12 PM
Bios saves OC settings, loads stock speed Mr. Cipher Troubleshooting 3 November 8, 2007 02:09 PM
initial settings Jim CPU's and Motherboards 3 July 23, 2007 03:17 PM
Check your default HD settings sswilson Troubleshooting 5 July 7, 2007 06:37 PM
