Old August 12, 2010, 06:49 PM
Default OC 955BE with m4a79xtd evo mobo
hey guys i have my machine OCed to 3.6 but cant get it stable above that. I go into the bios to try and change the vcore but it doesnt accept anything other than AUTO. I want to reach a minimum of 3.8 possibly 4.0.
running prime95 at 3.6 with vcore of 1.33v for 4 hours and staying 47c.
im running
proc- amd 955BE
mobo- m4a79xtd EVO
ram- corsair ddr3 1600
heatsink- hyper 212+
psu- ocz fatality 550w
Old August 12, 2010, 07:04 PM
how are you checking voltages/temps? 3.6 is not bad at all.
use everest if possible.
Old August 12, 2010, 07:15 PM
im using pc probe2 and amd overdrive, like to double check 2 different programs to make sure the temp and voltage corroborates
EDIT: I think the voltage is locked in the bios i'll try and get a closer look at the mobo and see if I missed in pins to unlock it in the bios. the mobo manual bios looks different than what my bios actually looks in the jumper free configuration tab so I dunno, any help would be much appreciated thanks all.
Old August 16, 2010, 08:58 AM
Biff73's Avatar
im running
proc- amd 955BE
mobo- m4a79xtd EVO
Up your Cpu vcore to 1.45v,raise multi but keep bus no higher than 200 if u want stability,Check this out:
CPU-Z Validator 3.1
Intel Core i7 [email protected]@1.375v
Gigabyte X99 SOC
G-Skill Ripjaws4 X DDR4 2666 CL45 [email protected]
4x Zotac GTX 970 [email protected]/1850 SLI/with EK Full block Clear
Corsair 900D
Alphacool monsta 360 wc custom loop with 6 xGentle typhoon 1850rpm
Seasonic X1250 Modular 1050w 80+Gold PSU
2xWDC 1TB Caviar Black
OCZ Vertex 4 256gb SSD
RGB Led kit
Edifier S550 295W RMS 5.1 ch Speakers
Logitech G600 MMO Mouse
Ducky Shine 2
Old August 17, 2010, 02:24 PM
well the problem i"m having is that for some reason bios wont let me raise the vcore. I can hit the +/- buttons but it wont set. I hit enter it clears the vcore back to AUTO, is there any other way to get the voltage to set without hit enter?
haf 922, amd 955BE, m4a79xtd EVO, 4gb corsair XMS 1600 8-8-8-24, hyper 212+, ati 4850 1gb, 550w ocz fatality series.
Old August 18, 2010, 02:14 AM
Biff73's Avatar
Try setting all CPU/DRAM tabs to manual,if it still does'nt help try upgrading Bios
Gigabyte X99 SOC
Corsair 900D
RGB Led kit
Ducky Shine 2
Preliminary 955BE C3 OC results Koslov Overclocking, Tweaking and Benchmarking 4 February 5, 2010 07:18 PM
PhenomIIX4 955BE + 5850; ASUS M4A785TD-V Evo good choice? 15Down New Builds 8 December 27, 2009 03:36 PM
PhII 955be wonky sensors? sswilson CPU's and Motherboards 11 September 29, 2009 12:53 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
