Old August 6, 2010, 04:46 PM
Prolab's Avatar
Default BE 965 + prime 95
Hey Guys,
I was running my 965 3.8 ghz a few hours ago and within 5 mins of the test, i keep getting rounding errors. So ive searched around and it turns out my OC isnt stable. So i loaded the optimized defaults and ran the test with stock clock.
So far after 2 hrs (and counting) no errors, no BSOD, freezing, etc.
Now, ive searched the forums and came across this http://www.hardwarecanucks.com/forum...-temps-ok.html and read through the post. And it seems like the temp on my 965 (when using prime) goes as high as 65C. Im using Core temp 0.99.7 + CPUID Hardware monitor to monitor temps.
My vcore (idle) is 1.07v, but full load is 1.47v. Core temp (idle) 38C, ambient temp - 23C.
I believe its high - stressing the CPU and RAM for 2+ hours. Now before i OC this rig any further, any way i can reduce the temp besides adding more fan and/or a newer case?
Im using a thermaltake V9, stock cooling fan, CoolIT push/pull configuration, stock 4890.
This is how she sits ATM:
How long should I run stress tests (I use prime 95) appplejack Overclocking, Tweaking and Benchmarking 31 August 10, 2009 10:05 PM
Random BSODs on Prime stable system. Realityshift Troubleshooting 17 March 17, 2009 10:13 PM
Testing Intel Burn Test 64 and Prime 95 64 (Help?) appplejack Overclocking, Tweaking and Benchmarking 1 January 11, 2009 04:53 PM
Prime 95 Error RogerzRig Overclocking, Tweaking and Benchmarking 52 February 20, 2008 10:03 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 10:05 AM
