Old August 5, 2010, 08:47 PM
Default I5 750 with Hyper 212 Overclocking Help Please
Hi guys,
Looking for someone familiar with overclocking this particular setup...
Here's my total setup:
CM 690 II Advanced
I5 750
G.Skill Ripjaws 4GB
Corsair TX650
Hyper 212 using Actic Silver 5 (push pull configuration)
Asus p7p55d-e Motherboard
.... Anyways, i got the Hyper 212 with the intention of hopefully getting my cpu up around 3.8-4ghz... Just for the hell of it I decided to run Prime95 PRIOR to overclocking or adjusting any settings in the bios. After about 6 minutes Coretemp shows me about 59C on each core on average.
Does this seem high? Do I have overclocking room?
Also, I didn't see one.. but if anyone has an overclocking guide/tutorial for an asus 1156 board that would be great, if not.. If you happen to know how I should go about doing it please let me know. Thanks guys, really looking forward to using this new computer!
Old August 5, 2010, 09:14 PM
59c on prime is not too bad :)
keep pushing till you reach around 70, altough ppl around here say even 75 is not warm enough :)
around 90c i think itll throttle itself down.
Old August 5, 2010, 09:25 PM
martin_metal_88's Avatar
58 is fair and right. We all have our temp. My I7 860 can get up to 88-89 at 4Ghz under Linx and it's fine because I know that a game or anything that is not stress test wont ever take it over around 75. You have to make a difference between use and stress test. if you get 59 in linx then a game will probably be around 50 so you are safe.
Old August 5, 2010, 11:26 PM
I thought I read that these chips shouldn't go over 70C though without damaging them though?
Maybe I read wrong... What would be safe temperatures?
Old August 5, 2010, 11:32 PM
in use 24/7? perhaps mid sixties. but again, i see ppl run them mid seventees to low 80's
Old August 6, 2010, 08:02 AM
it's really not a problem at 59C. I don't think 80+C under 100% load stress test is a problem either, see lots of people doing that when stress testing. Like mm said, you won't reach those temps on normal use.
Old August 6, 2010, 09:05 AM
You read wrong. Don't worry unless you start getting above 90. And don't listen to dangtx, since he has no idea what he's talking about.
Old August 6, 2010, 09:43 AM
Well If you read on Intel site they probably list like above 70 will damage your CPU but this is their said. In real life a CPU can last under much higher condition. In fact, the temp is not the issue, the power it need to reach these temp is. so OC this little baby like she want you to do!
Old August 6, 2010, 10:03 AM
Intel's site doesn't say that. They list a thermal spec which has nothing to do with safe limits, although people often mistake it for being that.
Old August 6, 2010, 10:12 AM
I don't really know I never use their site for that:P experience tell me when a CPU is to hotBut there is certainly a safe operating temp listed somewhere.
i7 930 with hyper 212 heatsink plus? dbear Air Cooling 15 July 13, 2010 03:05 PM
CoolerMaster Hyper 212+ performance on i7 marstedt Air Cooling 8 May 30, 2010 12:15 AM
hyper 212 plus install tips Rescue119 Air Cooling 19 May 7, 2010 07:32 AM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 04:56 PM
AMD build help (hyper 212) bumfloss New Builds 6 September 9, 2009 03:34 PM
