  #31 (permalink)
Old August 10, 2010, 12:25 PM
otl otl is offline
Trial Member
Ambient temp 23c
  #32 (permalink)
Old September 17, 2010, 09:33 AM
Chalaska's Avatar
Just saw the ambient temps and your new temps @ 4ghz. Not bad, but I'd suggest OCCT for 8 hours.
Last edited by Chalaska; September 17, 2010 at 09:36 AM. Reason: didn't see ambient temps, found them lulz
  #33 (permalink)
Old September 17, 2010, 09:45 AM
Closed Note's Avatar
Originally Posted by Dot Merix View Post
I thought I read that these chips shouldn't go over 70C though without damaging them though?
Maybe I read wrong... What would be safe temperatures?
Temps aren't killing CPUs, but voltages are :)
i7 930 with hyper 212 heatsink plus? dbear Air Cooling 15 July 13, 2010 03:05 PM
CoolerMaster Hyper 212+ performance on i7 marstedt Air Cooling 8 May 30, 2010 12:15 AM
hyper 212 plus install tips Rescue119 Air Cooling 19 May 7, 2010 07:32 AM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 04:56 PM
AMD build help (hyper 212) bumfloss New Builds 6 September 9, 2009 03:34 PM
