Originally Posted by Zero82z Well, then you'd be wrong. The VID tells you how much voltage the CPU needs to run at stock. However, that often has absolutely no impact on the amount of voltage you need to hit really high speeds. A CPU that has a low VID can still require a lot of voltage for higher overclocks, or may not even overclock too well altogether. |
Ok, i see where your coming from.. Just generally from what ive seen, the lower the vid, the lower the volts needed for a nice OC. But anyway, im looking for a little help.. This bios is scary compared to my old 775 rig
so far ive been able to get to 3.6Ghz (173x21) and i cant seem to get it up any higher. Im a big noob with socket 1366, but so far i've tried lowering the speed of my ram, increasing VTT/QPI volts, increased the vcore, and still cant seem to get it to go past windows logo. I think it might have been a bios issue, it was only reading 4gb of ram so i just updated it. Im going to give it another shot now that it seems to be functioning properly, but incase its still a no go, any advice on what other voltages to increase or any other settings i should change?
By the way, im not going for a massive overclock, just 4.0
