Old July 30, 2010, 07:49 AM
bvsbutthd101's Avatar
Default Can't overclock pass 4 ghz without ram messing up
When I go to overclock my i7 930 pass 4 ghz is automatically overclocks the ram which I know is normal, I have 4 gb of corsair dominator 1600 mhz ram, so when I overclock pass 4 ghz, say like 4.2 ghz. When I boot my system up it says I have 4 gb of ram but 1.99 gb is usable, I would really like to overclock higher then 4 ghz.
Old July 30, 2010, 08:19 AM
martin_metal_88's Avatar
Maybe a lack of voltage on the memory or your board really don't want to OC. I don't know EVGA 1366 board very well but the reason why this happen is surtenly due to voltage somewhere.
Old July 30, 2010, 08:59 AM
I've tried to increase the voltage, right now I have it overclocked to 4 ghz and the memory is around 1137 mhz, I leave the memory voltages on auto right now, it says it's at 1.5v, when I overclock my cpu to 4.2 ghz the ram goes up to 1221 mhz, do you have any idea how much I should increase the voltages?
Old July 30, 2010, 09:24 AM
Increase it to 1.65V. Also, have you raised the QPI/VTT voltage at all? If not, try jacking that up to around 1.3V.
Old July 30, 2010, 09:38 AM
sswilson's Avatar
What happens if you downclock the ram (drop the multiplier)?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old July 30, 2010, 09:52 AM
Arinoth's Avatar
Whats the max your ram is rated to run at?
Here I am: here I remain
Old July 30, 2010, 10:10 AM
He's already running the lowest multiplier.
Old July 30, 2010, 02:14 PM
Well my ram is rated at 1600 mhz, at 1.65 v and timings at 8-8-8-24
I'll try and raise the qpi/vtt cause I haven't even touch them
Old July 30, 2010, 02:46 PM
tried increasing those voltages, didn't do anything, still showing 1.99 usable.
Old July 30, 2010, 05:26 PM
ZZLEE's Avatar
You may need more ram. The Evga bords like 3 or 6 slots populated.
whitch slots are your ram in? Check moutherbord manule fore witch slots to populate with only 2 sticks.
It will only run in duel channel with two stick if it is like my EVGA X58 SLI board.
Two Overclock "Sammy" says 3 sticks of ram in.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Overclock on RAM quikgp RAM 6 December 12, 2009 12:59 PM
7 ghz overclock wow Shadowmeph Press Releases & Tech News 8 November 16, 2009 09:57 AM
[WTB] seeing that purolator is messing up, i need mobo+cpu locally.... _dangtx_ Buy/Sell & Trade 0 October 23, 2009 08:45 AM
Q6600 overclock to 3.0 GHz HermesĄ˘ RAM 10 November 17, 2008 09:06 PM
How does this ram overclock? klaiboi RAM 7 March 23, 2008 05:42 PM
