Old July 14, 2010, 05:55 PM
bvsbutthd101's Avatar
Default Overclocking my i7 930?
I got a 930 about 2 weeks ago and I can't seem to get a stable overclock, I'm still a little new with overclocking, plus this is my first i7, I had q6600 before and that overclocked pretty easy. I have a EVGA FTW3 motherboard. I tried using the dummy OC option in the bios and it overclocked to 3.2 ghz, but when I went to prime95 it, my computer froze.
If anyone has any settings that I could try, please post
Old July 18, 2010, 03:36 PM
Sorry for the late reply, I just overclocked my 930 for the first time today.
I just went the "easy way" of OCing it, for my first time. Basically just copied this guys settings, YouTube - Overclocking the Core i7 920 (HD)
Bump CPU voltage to 1.37500 and BCLK to 180. Managed to acheive 3.96 OC. Stable thus far running in prime95
Old July 18, 2010, 04:23 PM
1.375V is WAY too high for that kind of an overclock. I would try 1.3V and see if it's stable for you. That will cut down considerably on power consumption and temperatures.
Old July 18, 2010, 06:29 PM
should I change any of the other voltages, or just the vcore
Old July 18, 2010, 06:37 PM
Tell me what your VTT is set to and I can tell you if you should change that. Your RAM voltage should be set according to what the kit is rated for (probably 1.65V). Everything else should be fine.
Old July 18, 2010, 07:04 PM
well everything is set to default/auto right now, but the VTT is at +0mv
Old July 18, 2010, 07:06 PM
Okay, then leave the VTT as it is for now and see if you're stable when overclocked. If not, then play around with it.
Old July 18, 2010, 07:09 PM
these settings are for 4.0 ghz right?
Old July 18, 2010, 07:29 PM
Which settings? The ones I'm giving you are general tips for hitting whatever overclock you might want to hit. If you're talking about the video, then I haven't watched it and I don't plan to.
Old July 18, 2010, 07:53 PM
Nevermind, forget what I said, I didn't even watch the video either, I have one more question though, I just overclock my cpu to 4.0 ghz but when I open the control panel in windows, it my memory is saying 1.99 usable
I have 4 gb in total, is this a problem?
i7 930 Help! soulicro Overclocking, Tweaking and Benchmarking 3 August 10, 2010 01:32 PM
i7 920 vs i7 930 Scottyboy85 CPU's and Motherboards 10 July 15, 2010 03:29 PM
i7 920 or 930 phoenixrage Overclocking, Tweaking and Benchmarking 16 June 7, 2010 02:21 PM
I7 930 32nm??? Silvgearx CPU's and Motherboards 20 February 28, 2010 09:16 AM
