Old July 13, 2010, 06:03 AM
kruzn4evr's Avatar
Default Prime95 question
I'm messin' around with some OC'ing on the Widow 980x and when I go to run Prime95 I get this (see pic). What I'm not sure of is, is this because my OC is unstable? This has been happening on a few occasions, even when my OC was mild and appeared stable in everything else I threw at it including Everest, LinX and any games.
Any thoughts?
Old July 13, 2010, 06:07 AM
Arinoth's Avatar
That looks more like prime95 freezing or having conflicting issues with windows itself rather then a stability issue there. Try re-downloading/installing it and see if this happens again
Here I am: here I remain
Old July 13, 2010, 06:08 AM
chrisk's Avatar
Folding Captain
Try running as administrator? UAC off?
Fold for team #54196
Old July 13, 2010, 06:10 AM
sswilson's Avatar
But it doesn't happen all of the time? If that's the case then I'd suspect there is an instability of some form. I've run prime95 under win7 ultimate 64bit without any problems. Is there a particular time frame that it seems to happen in?
Old July 13, 2010, 06:17 AM
kruzn4evr's Avatar
I am running as admin with UAC off and it seems to usually happen at the start of Test 2 for the 80000 run......I think I will try dl'ing and installing again and see what happens
Old July 13, 2010, 06:24 AM
gingerbee's Avatar
why do you install it? just unzip and run. but this sounds a little strange i think it may be your oc. jm2cents
Old July 13, 2010, 06:30 AM
chrisk's Avatar
Folding Captain
Try memtest...maybe prime95 is hitting some bad ram that your other utilities are not. Memtest86+ - Advanced Memory Diagnostic Tool
Old July 13, 2010, 06:32 AM
kruzn4evr's Avatar
ahhhh....good idea, will try that next if it does it again, running it now and so far so good but hasn't hit the 80000's yet.
Old July 13, 2010, 06:34 AM
kruzn4evr's Avatar
Thats what I meant, I don't think its the OC only because nothing else stops or freezes, I just close out Prime and carry on, everything else is fine.
Old July 13, 2010, 06:37 AM
sswilson's Avatar
Yeah, if it's happening at pretty well the exact same spot all of the time, pretty sure it's the OC.
Prime95 Crash NightRain Troubleshooting 5 May 12, 2010 06:11 AM
prime95 without cooler! 486 Air Cooling 20 February 11, 2009 11:46 AM
Prime95 Error Vegaslife Overclocking, Tweaking and Benchmarking 6 January 19, 2009 10:55 AM
Need some help with prime95 Gameplaywarrior O/S's, Drivers & General Software 2 November 29, 2008 12:16 PM
Prime95 v2.51 enaberif Overclocking, Tweaking and Benchmarking 6 July 25, 2007 08:34 PM
