<~----> My 75W PC - Hardware Canucks
Old June 23, 2010, 09:22 PM
lowfat's Avatar
Default My 75W PC
And when I say 75W I mean under LinX load.
The system consists of the following:
Pentium G6950 @ 2.8GHz, 0.94Vcore, 1.05Vtt, 1.0Vgpu.
Gigabyte H55M-USB3
2x1GB of Kingston Value DDR3 @ 6-6-6-24, 1.3V.
40GB X25-V
1TB Seagate 7200.12
RocketRAID 2314 'RAID' card
1050W Enermax Revo85+
This is the system idle.
And the system under LinX load. Assuming 80% efficiency of my PSU, I am using a whopping 6% of its power.
Now I also have another 8 HDD's (1.5TB 7200.11's) that are in an external enclosure. And these are the power figures w/ them on and spinning.
Idle.
LinX load
Not to shabby for a 9 HDD machine.
Old June 23, 2010, 10:31 PM
Mook06's Avatar
that is awesome, im currently looking into a low power portable system, this gives me lots of hope, as i will need a raid + decent cpu
Old June 23, 2010, 11:11 PM
It would use even less power if you swapped the PSU. I'd be surprised if the Enermax is even 80% efficient at the loads you're running. Most likely 70-75%.
Old June 23, 2010, 11:27 PM
Jake_HT's Avatar
I was thinking the same thing... PSUs aren't as efficient with low loads as they are with medium loads.
http://jakeht.deviantart.com/
Old June 24, 2010, 08:22 AM
lowfat's Avatar
Ya I am aware of this. I have a 420W Seasonic M12D that I'll likely throw in at sometime. I just used the Revo+ because I had already cut extended all the cables to fit this case perfectly.
Old June 24, 2010, 08:24 AM
gingerbee's Avatar
wicked build there power = performance which is pretty good i bet
Old June 24, 2010, 09:00 AM
good god. thats one nice little bugger lol
but...100w? lol
Old June 24, 2010, 09:08 AM
Would you mind trying to fold with that? I've been curious about the PPD on that CPU, but haven't been able to find anything.
Old June 24, 2010, 09:17 AM
Mark's Avatar
LOL. I idle at 320 watts and hit 432 running prime :).
CHEERS
Old June 24, 2010, 10:27 AM
420W M12D? That doesn't exist.
