Old June 11, 2010, 09:19 AM
Default Quick question about OCing and cpu VID
From my understanding, VID means the stock voltage that a chip runs at?
For example, one of my i5 750 shows 1.02 in cpuz at idle, stock settings.
Another 750 shows 0.86 in cpuz at idle, stock settings.
Although, they are on different motherboards (would that affect VID?)
Based on this, can I assume that the second 0.86 voltage one will overclock better?
Or not very related?
I am getting stable 4ghz at 1.25 vcore on the first cpu, and haven't tried OCing the other. Should I expect better results?
Thank you!
Old June 27, 2010, 09:34 AM
ForTheGG's Avatar
Yes, lower VID's tend to overclock better at lower voltages. That's only for the chip though, you need to make sure all of your other components compliment the chip nicely. Putting your i7 860 in a Biostar P55 board is not the greatest combo xD
"Sang Noir"
-Cooler Master Storm Sniper Black Mesh Edition
-Intel Core i7 920 D0 @ 4.116GHz 1.318VCore 24/7 HT On
-Corsair H-50 + 2x Cooler Master R4
-Asus RoG Rampage III Extreme
-6GB OCZ Platinum Triple Channel DDR3-1600 [7-7-7-20]
-2x EVGA GTX 295+ Quad SLI
-Corsair HX-1000
-WD 160GB Raptor 10000RPM
-WD 1000GB Black 7200RPM
http://valid.canardpc.com/cache/banner/1249140.png
Old June 27, 2010, 11:00 AM
A CPU with a lower VID does not necessarily reach a higher maximum frequency than one with a higher VID. All it means is that you will probably be able to reach higher overclocks with stock voltage.
quick question gingerbee O/S's, Drivers & General Software 6 May 19, 2009 05:12 AM
Quick question jspot69 HTPC Systems & Software 4 February 6, 2009 06:39 AM
Quick question Zippoh New Builds 10 December 2, 2008 09:48 PM
quick question... omgwtf O/S's, Drivers & General Software 14 July 22, 2008 05:31 PM
Quick Question. Khronos Display Units 2 January 7, 2008 02:16 PM
