Old November 16, 2007, 12:07 PM
Trial Member
Default OC'd a little 2 much me thinks.
Name:  ahhh crap its going to fry.bmp
Size:  170.7 KBK so im new at this ... how did i get this result please help me... there seems to be something wrong ... its lasts for a sec or two.. if it dosent cause a re-boot...
btw its a 1.8 winne... AMD 3000+
Brand = AMD Athlon(tm) 64 Processor 3000+
Family = 15
Model = 15
Stepping = 0
L1 Instr Cache Size = 65536
L1 Data Cache Size = 65536
L2 Cache Size = 524288
L3 Cache Size = 0
Feature flags:
CPUID 00000001[edx]=0x078bfbff:
fpu : Processor supported vme : Processor supported
de : Processor supported pse : Processor supported
msr : Processor supported pae : Processor supported
mce : Processor supported cx8 : Processor supported
apic : Processor supported sep : Processor supported
mtrr : Processor supported pge : Processor supported
mca : Processor supported cmov : Processor supported
pat : Processor supported pse36 : Processor supported
cflush : Processor supported ds : No processor support
acpi : No processor support mmx : Processor supported
fxsr : Processor supported sse1 : Processor supported
sse2 : Processor supported ss : No processor support
htt : No processor support tm : No processor support
sbf : No processor support
CPUID 00000001[ecx]=0x00000000:
tm2 : No processor support est : No processor support
cid : No processor support sse3 : No processor support
CPUID 80000001[edx]=0xe3d3fbff:
tsc : Processor supported msr : Processor supported
pae : Processor supported mce : Processor supported
cx8 : Processor supported syscall : Processor supported
mp : No processor support nx : Processor supported
ammx : Processor supported mmx : Processor supported
fxsr : Processor supported lm : Processor supported
x3dnow : Processor supported 3dnow : Processor supported
========== Operating System Information ==========
Microsoft Windows XP Professional Service Pack 3, v.3180 (Build 2600)
========== Motherboard Information ==========
Motherboard Vendor: DFI
Motherboard Version: 2.0
Motherboard Model: LP NF4
========== DirectX version Information ==========
DirectX 9.0c (5.3.2600.3180)
========== Driver Version Information ==========
Audio Driver 4.65 (6.14.0465.0)
GART Driver Not reported
Graphics Driver 63.71 (6.14.11.6371)
Ethernet Driver 50.25 (1.00.03.05025)
IDE Driver Not reported
nTune 5.00.11
========== Chipset Information ==========
MCP Version nForce4 A3
SPP Version Not reported
A3
========== Processor, Bus, and Memory Speed Information ==========
CPU Speed = 1917.349
CPU Multiplier = 9.000
FSB Frequency = 213
Memory Frequency = 426.000
PCIE Frequency = 2575
tRas = 5
tRcd = 3
tRp = 2
tRc = 0
tWr = 0
tRrd = 0
tRwt = 0
tWtr = 0
tWrrd = 0
tWrwr = 0
tRdrd = 0
tRef = 0
========== GPU's Core and Memory Speed Information ==========
NVIDIA GeForce 6600
GPU Core Speed = 300
GPU Memory Speed = 500
========== System Voltage Information ==========
CPU Voltage = 1.450 v
Core Voltage = 1.532 v
AGP Voltage = 0.000 v
Aux Voltage = 0.000 v
Memory Voltage = 2.864 v
========== Processor and System's Temperature Information ==========
CPU Temperature = 31 C
System Temperature = 44 C
GPU Temperature = Not Reported
Old November 16, 2007, 12:21 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Probably mem related, what kit you using?
Best to test the max of ram and cpu independently so you know where your errors are coming from.
Old November 16, 2007, 12:41 PM
donimo's Avatar
your pci-e speeds are 2575mhz? Mine is 100mhz...
Plus that is a HHHHUUGE overclock on a 3000+ isnt it from 1.8 to almost 4ghz?!??
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old November 16, 2007, 01:48 PM
Synth's Avatar
He's not OC'ed to ~4ghz, he just upped his FSB from 200 to 213mhz, and his PCI-E to 2575mhz ...
Or the software reporting is just wrong.
Old November 16, 2007, 03:30 PM
donimo's Avatar
ok, down below it says that, but it the screen cap he posted it says his CPU speed is 3900mhz.
And how it the heck you can even get a PCIE speed up to 2500mhz is beyond me...
Am I missing something, my pcie speed is 100mhz, thats like a 2500% overclock...
Old December 1, 2007, 10:33 AM
if i were you i wouldnt even use nvidia overclocking stuff it just creates big system stability issues
EVGA Nvidia Nforce 680i,Core2duo E6400@3.69ghz, 4x1000mb OCZ Plainum 6400ddr2 ,250gb Seagate Barracuda, Zalman Reserator 1 Plus Watercooling system
Old December 1, 2007, 10:13 PM
qwerty's Avatar
What cooling are you using to get those results? Phase change? Dice? LN2?
What core are you using?
That is beyond the far World record if you can get it to settle down.
Post more info please neo...
Old December 1, 2007, 11:28 PM
llama_egg's Avatar
That...just...no...that shouldn't even be possible...yes, post more info, please o_O
Old December 2, 2007, 12:30 AM
JD JD is offline
Yeah seriously, what the heck?
4GHz on an AMD 3000+ and a 2.575GHz PCIe bus along with nearly 900MHz DDR memory?!
And such low voltage too...
Something is fishy here.
best way to test an OC'd gpu djnocide Video Cards 8 February 26, 2008 08:47 AM
Difference between OC'd Q6600 and stock Q6700, etc... Seaward Overclocking, Tweaking and Benchmarking 4 February 4, 2008 01:28 PM
