-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Max temperature (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/3282-max-temperature.html)
Vinnie November 15, 2007 08:26 PM
Max temperature
I have a AMD X2 4600 2.4Ghz.
I've overclocked it to 2.71Ghz, this is with a Thermaltake Blue Orb fan cooling the CPU
Idle Temperature is 33c
Load Temperature is 48C
Am I ok with those temperatures, or is it getting to hot at load???
reaverclan November 15, 2007 08:44 PM
thats fine for temps i'm e6420 2.13 stock @3.2grz with idle being 30, and load being 43
Shredder November 24, 2007 12:06 PM
Here is the path to the spec sheets for your equipment, Max Temperatures are there for you to check out.:thumb:
BrothaInFaith November 24, 2007 02:44 PM
you're good up to 65 degrees. truth be known you probably wouldnt see problems till you topped 80. but keep it below 65 if you dont want to unduly shorten its life
Vinnie November 28, 2007 09:08 PM
That's great.....Thanks guys.:thumb:
