Old June 1, 2010, 02:03 PM
Default Differences b/w System & CPU-Z
Stupid question. But I'm real curious.
I overclocked in the BIOS, i.e. Multiplier 13 X FSB 250. But the overclock @ 3.25GHz only shows-up in CPUz.
Under Control Panel --> Systems, it still shows stock clock @ 2.6GHz. Anybody know why?
Thanks.
Old June 1, 2010, 02:19 PM
gingerbee's Avatar
normal it happens
Old June 1, 2010, 02:35 PM
use cpuz and dont worry about the os. :)
Old June 1, 2010, 02:36 PM
Arinoth's Avatar
Windows is dumb and just reads the stock information
Here I am: here I remain
Old June 1, 2010, 05:57 PM
Cool. Thanks everyone!
Old June 27, 2010, 09:39 AM
ForTheGG's Avatar
Windows has a hard time reading CPU multipliers past stock, it tells me my i7 runs at 3.9 because it can't read the 21st multiplier.
"Sang Noir"
-Cooler Master Storm Sniper Black Mesh Edition
-Intel Core i7 920 D0 @ 4.116GHz 1.318VCore 24/7 HT On
-Corsair H-50 + 2x Cooler Master R4
-Asus RoG Rampage III Extreme
-6GB OCZ Platinum Triple Channel DDR3-1600 [7-7-7-20]
-2x EVGA GTX 295+ Quad SLI
-Corsair HX-1000
-WD 160GB Raptor 10000RPM
-WD 1000GB Black 7200RPM
http://valid.canardpc.com/cache/banner/1249140.png
Old June 27, 2010, 10:57 AM
Windows always assumes you are using the stock multiplier. It will usually report correctly if you only changed the FSB or base clock, but if you change the multiplier then it will be wrong.
Hardware Canucks Code of Conduct & Infraction System Gav Site Announcements 0 April 15, 2010 02:37 PM
CPU Temperature Differences silent1mezzo Troubleshooting 8 September 4, 2009 09:13 PM
Thermochill PA120.3 handle CPU & MOSFET & NB ? TAOTAO161 Water Cooling 3 May 10, 2008 08:31 PM
I have a BOXX dual AMP 2200+ system that i believe is overheating maytagazn Troubleshooting 3 April 11, 2007 08:11 PM
