Old May 31, 2010, 10:59 AM
Default Unlock AND overclock at the same time???
I have an AMD Phenom II X3 710. I managed to unlock the 4th core (woohoo!), and ran prime95 stable for 10+ hours. Been using these settings for a while now, with no gaming issues, video conversion issues, etc.
Question, has anybody unlocked their 4th core, AND overclocked their cpu at the same time? I tried to do this, but ack, it never worked. Always got the BSOD no matter what I tried.
Tried to underclock the RAM, played with timings, etc. Just curious if anybody was successful. I'm using the ASUS M4A78L-M, CM Hyper 212+, OCZ Platinum Edition 2x2GB PC2-8500 DDR2-1066MHz.
Thxthx.
Old May 31, 2010, 12:49 PM
i unlocked a PII 550be ..i overclocked it to 3.8ghz with stock hsf.@1.36v.
atm its 3.6 x4 theres a link in my sig...
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old May 31, 2010, 01:12 PM
^^^THanks. hummm...is the black edition easier to OC? I dun have the BE, just normal 710.
As soon as i change the voltages and multipliers, i can't even post. I dunno, maybe it's the mobo. Temps seem to be okay.
Old May 31, 2010, 01:20 PM
usually people need more juice to get the 4th or 3,4 cores going. usually. athlon II's and phenom II's can and will get over 3.5 ghz. question is, how much juice do they need?
thuban's are made differently, better clockers. the dual core alternatives to come about will be interesting, to say the least.
Old May 31, 2010, 01:21 PM
sswilson's Avatar
What voltages are you bumping? Remember that the stock voltages for everything (NB & HT especially) are based on 3 cores rather than 4. Could be that you need to bump those up, or it's also possible that your 4'th core was disabled because it couldn't run stable at speed.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old May 31, 2010, 01:41 PM
^^^At the moment, with the unlocked 4th core, i'm running at stock speeds (2.6GHz, i.e. 13x 200fsb). CPU Over-voltage set to 1.325V, and everything else at auto.
Memory is at stock settings. 533MHz @ 5-5-5-18 @ 2.1 Memory Over-voltage.
Ran these under Prime95 for over 10 hours, with no problems. Games weren't an issue either.
Only when I try to overclock, the thing doesn't even POST. Tried playing around with the multipliers, fsb, voltages, but no luck.
Old May 31, 2010, 02:16 PM
sswilson's Avatar
Definitely suggest you find out what your NB & HT voltages are at stock and bump those up a bit before you OC. When you're trying to OC, are you doing baby steps, or are you trying to jump directly to what your 3 cores were able to do?
Old May 31, 2010, 02:27 PM
^^^ Just using the settings i have now, and upping the fsb.
So, first, I basically kept everything as is, but unlocked the 4th core and up'd the voltage to 1.325V. Everything runs stable at this point.
Then, I go back to the BIOS and try to up the FSB, keeping the multiplier the same at 13x. Didn't work, so i up'd the voltages, etc.
Still didn't work. I guess to answer your question, jumped directly to what my 3 cores were able to do.
Old May 31, 2010, 02:30 PM
sswilson's Avatar
Try bumping the FSB by small steps so that the other auto settings will be able to adjust.
Old May 31, 2010, 02:36 PM
^^^ LoL, did that. Went up by 5MHz intervals, but failed on the first attempt.
Ugh, i definitely think it's the mobo. Limited in it's OC'ing capabilities. Just wondering if anybody else had better luck than I.
Thxthx sswilson!
help me unlock my 4th core..! ultraman7k Overclocking, Tweaking and Benchmarking 8 May 31, 2010 08:42 PM
Core Unlock Switch? jcmaz CPU's and Motherboards 10 March 13, 2010 08:43 AM
Successful 550 unlock (i think) johnnyblazzwa Overclocking, Tweaking and Benchmarking 17 March 4, 2010 10:17 AM
AMD unlock phil3_66666 CPU's and Motherboards 5 November 17, 2009 06:46 PM
Help!! I can't unlock these RAID Drives!? bushwickbill Troubleshooting 38 July 30, 2008 10:51 PM
